%3CLINGO-SUB%20id%3D%22lingo-sub-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EUtilit%C3%A0%20di%20selezione%20delle%20colonne%20migliorata%20tra%20dati%20numerici%20e%20caratteri%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHo%20notato%20anche%20nella%20piattaforma%20di%20distribuzione%20che%20se%20abilito%20un%20commutatore%20di%20colonne%20tra%20colonne%20numeriche%20e%20caratteri%2C%20JMP%20non%20%C3%A8%20un%20fan.%20Quando%20si%20passa%20dalle%20colonne%20Numerico%20a%20Carattere%2C%20viene%20visualizzata%20una%20X%20grande%20che%20indica%20%22La%20colonna%20deve%20essere%20numerica.%20Nessun%20dato%20da%20analizzare.%20%22%3C%2FP%3E%3CP%3EPresumo%20che%20questo%20possa%20essere%20risolto.%20So%20che%20il%20tipo%20di%20output%20e%20le%20statistiche%20desiderate%20sono%20di%20una%20modalit%C3%A0%20mista%2C%20ma%20dovrebbero%20rientrare%20nelle%20possibilit%C3%A0%20di%20JMP.%3C%2FP%3E%3CP%3EInoltre%20da%20notare%3A%20se%20una%20colonna%20%C3%A8%20nominale%20ma%20continua%2C%20JMP%20valuta%20erroneamente%20i%20dati%20come%20se%20fossero%20numerici.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Improved Column Switcher Utility Between Numeric and Character Data
I've noticed even in the Distribution platform that if I enable a Column Switcher between Numeric and Character columns, JMP is not a fan. When going from the Numeric to Character columns a big X appears and states "Column must be numeric. No data to analyze."
I would assume this can be fixed. I know that the type of output and desired statistics are of a mixed mode, but should be within the possibilities of JMP.
Also of note - if a column is Nominal but Continuous, JMP erroneously assesses the data as if it were Numeric.
