%3CLINGO-SUB%20id%3D%22lingo-sub-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAm%C3%A9lioration%20de%20l'utilitaire%20de%20changement%20de%20colonne%20entre%20les%20donn%C3%A9es%20num%C3%A9riques%20et%20de%20caract%C3%A8res%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJ'ai%20remarqu%C3%A9%20m%C3%AAme%20sur%20la%20plate-forme%20de%20distribution%20que%20si%20j'active%20un%20s%C3%A9lecteur%20de%20colonne%20entre%20les%20colonnes%20num%C3%A9riques%20et%20caract%C3%A8res%2C%20JMP%20n'est%20pas%20un%20fan.%20Lorsque%20vous%20passez%20des%20colonnes%20Num%C3%A9rique%20%C3%A0%20Caract%C3%A8re%2C%20un%20grand%20X%20appara%C3%AEt%20et%20indique%20%22La%20colonne%20doit%20%C3%AAtre%20num%C3%A9rique.%20Aucune%20donn%C3%A9e%20%C3%A0%20analyser.%20%22%3C%2FP%3E%3CP%3EJe%20suppose%20que%20cela%20peut%20%C3%AAtre%20corrig%C3%A9.%20Je%20sais%20que%20le%20type%20de%20sortie%20et%20les%20statistiques%20souhait%C3%A9es%20sont%20d'un%20mode%20mixte%2C%20mais%20devraient%20%C3%AAtre%20dans%20les%20possibilit%C3%A9s%20de%20JMP.%3C%2FP%3E%3CP%3E%C3%80%20noter%20%C3%A9galement%20-%20si%20une%20colonne%20est%20nominale%20mais%20continue%2C%20JMP%20%C3%A9value%20%C3%A0%20tort%20les%20donn%C3%A9es%20comme%20si%20elles%20%C3%A9taient%20num%C3%A9riques.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Improved Column Switcher Utility Between Numeric and Character Data
I've noticed even in the Distribution platform that if I enable a Column Switcher between Numeric and Character columns, JMP is not a fan. When going from the Numeric to Character columns a big X appears and states "Column must be numeric. No data to analyze."
I would assume this can be fixed. I know that the type of output and desired statistics are of a mixed mode, but should be within the possibilities of JMP.
Also of note - if a column is Nominal but Continuous, JMP erroneously assesses the data as if it were Numeric.
