%3CLINGO-SUB%20id%3D%22lingo-sub-381438%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EImproved%20Column%20Switcher%20Utility%20Between%20Numeric%20and%20Character%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-381438%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EI've%20noticed%20even%20in%20the%20Distribution%20platform%20that%20if%20I%20enable%20a%20Column%20Switcher%20between%20Numeric%20and%20Character%20columns%2C%20JMP%20is%20not%20a%20fan.%20When%20going%20from%20the%20Numeric%20to%20Character%20columns%20a%20big%20X%20appears%20and%20states%20%22Column%20must%20be%20numeric.%20No%20data%20to%20analyze.%22%3C%2FP%3E%3CP%3EI%20would%20assume%20this%20can%20be%20fixed.%20I%20know%20that%20the%20type%20of%20output%20and%20desired%20statistics%20are%20of%20a%20mixed%20mode%2C%20but%20should%20be%20within%20the%20possibilities%20of%20JMP.%3C%2FP%3E%3CP%3EAlso%20of%20note%20-%20if%20a%20column%20is%20Nominal%20but%20Continuous%2C%20JMP%20erroneously%20assesses%20the%20data%20as%20if%20it%20were%20Numeric.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-381438%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EData%20Exploration%20and%20Visualization%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Improved Column Switcher Utility Between Numeric and Character Data
I've noticed even in the Distribution platform that if I enable a Column Switcher between Numeric and Character columns, JMP is not a fan. When going from the Numeric to Character columns a big X appears and states "Column must be numeric. No data to analyze."
I would assume this can be fixed. I know that the type of output and desired statistics are of a mixed mode, but should be within the possibilities of JMP.
Also of note - if a column is Nominal but Continuous, JMP erroneously assesses the data as if it were Numeric.
