%3CLINGO-SUB%20id%3D%22lingo-sub-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EVerbessertes%20Column%20Switcher-Dienstprogramm%20zwischen%20numerischen%20Daten%20und%20Zeichendaten%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20habe%20sogar%20in%20der%20Distributionsplattform%20festgestellt%2C%20dass%20JMP%20kein%20Fan%20ist%2C%20wenn%20ich%20einen%20Spaltenumschalter%20zwischen%20numerischen%20und%20Zeichenspalten%20aktiviere.%20Beim%20%C3%9Cbergang%20von%20den%20Spalten%20Numerisch%20zu%20Zeichen%20wird%20ein%20gro%C3%9Fes%20X%20angezeigt%2C%20das%20angibt%2C%20dass%20die%20Spalte%20numerisch%20sein%20muss.%20Keine%20Daten%20zu%20analysieren.%20%22%3C%2FP%3E%3CP%3EIch%20w%C3%BCrde%20annehmen%2C%20dass%20dies%20behoben%20werden%20kann.%20Ich%20wei%C3%9F%2C%20dass%20die%20Art%20der%20Ausgabe%20und%20die%20gew%C3%BCnschten%20Statistiken%20gemischt%20sind%2C%20aber%20innerhalb%20der%20M%C3%B6glichkeiten%20von%20JMP%20liegen%20sollten.%3C%2FP%3E%3CP%3EEbenfalls%20zu%20beachten%3A%20Wenn%20eine%20Spalte%20nominal%2C%20aber%20fortlaufend%20ist%2C%20bewertet%20JMP%20die%20Daten%20f%C3%A4lschlicherweise%20so%2C%20als%20w%C3%A4ren%20sie%20numerisch.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-381438%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EBenutzeroberfl%C3%A4che%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Improved Column Switcher Utility Between Numeric and Character Data
I've noticed even in the Distribution platform that if I enable a Column Switcher between Numeric and Character columns, JMP is not a fan. When going from the Numeric to Character columns a big X appears and states "Column must be numeric. No data to analyze."
I would assume this can be fixed. I know that the type of output and desired statistics are of a mixed mode, but should be within the possibilities of JMP.
Also of note - if a column is Nominal but Continuous, JMP erroneously assesses the data as if it were Numeric.
