This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
another suggestion which helps me currently is to use File > Save Session Script. If I save the session script each day before I shutdown my computer, and then I open and run that script each morning after I open fresh instance of JMP, then all of my analysis and my entire analytic workflow (everything in my home menu) is preserved, even the data tables that I did not explicitly save in memory (e.g. "Untitled 113").
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
