%3CLINGO-SUB%20id%3D%22lingo-sub-567422%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EGrafici%20con%20Graphlet%20per%20lavorare%20in%20PowerPoint%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-567422%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EVorrei%20aggiungere%20un'idea%20che%20consente%20agli%20utenti%20di%20esportare%20grafici%20con%20le%20funzionalit%C3%A0%20di%20graphlet%20e%20di%20incorporare%20i%20grafici%20interattivi%20in%20%E2%80%8B%E2%80%8Bpresentazioni%2C%20come%20PowerPoint.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-567422%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ERicerca%20sui%20consumatori%20e%20sul%20mercato%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EPersonalizzazione%20di%20massa%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECondivisione%20e%20comunicazione%20dei%20risultati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-567972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Grafici%20con%20Graphlet%20per%20funzionare%20in%20PowerPoint%20-%20Stato%20cambiato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-567972%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F45312%22%20target%3D%22_blank%22%3E%20%40JMPanie%3C%2FA%3E%20%2C%20Grazie%20per%20il%20tuo%20suggerimento!%20Abbiamo%20acquisito%20la%20tua%20richiesta%20e%20la%20prenderemo%20in%20considerazione.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-577327%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Grafici%20con%20Graphlet%20per%20lavorare%20in%20PowerPoint%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-577327%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F45312%22%20target%3D%22_blank%22%3E%20%40JMPanie%3C%2FA%3E%20%2C%20hai%20provato%20a%20salvare%20come%20HTML%20interattivo%20con%20i%20dati%20(o%20a%20pubblicare%20su%20JMP%20Live)%3F%20Ci%C3%B2%20fornisce%20una%20discreta%20quantit%C3%A0%20di%20interattivit%C3%A0.%20Tuttavia%2C%20il%20supporto%20per%20i%20graphlet%20non%20%C3%A8%20ancora%20disponibile.%20Ci%C3%B2%20richiederebbe%20molto%20lavoro%20e%20si%20sta%20studiando%20l'approccio%20migliore.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Graphs with Graphlets to work in PowerPoint
I would like to add an idea that allows users to export graphs with the graphlet features and embed the interactive graphs into presentations, like PowerPoint.
4 Comments
Hi @JMPanie, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
Hi @JMPanie, have you tried saving as Interactive HTML with Data (or publishing to JMP Live)? This provides a fair amount of interactivity. However, support for graphlets is not yet available. This would take a lot of work, and the best approach is being investigated.
mia_stephens
Hi @JMPanie , have you had an opportunity to try the suggestions provided above?
mia_stephens
Status changed to: Not Planned For Now
Moving to not planned for now, as this does not align with current priorities and would be difficult to implement. However, we will reopen if there is additional interest.
