%3CLINGO-SUB%20id%3D%22lingo-sub-666649%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EFehlerb%C3%A4nder%20f%C3%BCr%20Liniendiagrammelemente%20im%20Diagrammersteller%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-666649%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20diese%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIch%20verwende%20h%C3%A4ufig%20Liniendiagramme%20ohne%20das%20X-Element%2C%20sodass%20die%20Linie%20durch%20das%20gesamte%20Diagramm%20verl%C3%A4uft%20und%20einen%20zusammenfassenden%20Wert%20anzeigt%2C%20normalerweise%20den%20Mittelwert.Ich%20begann%20zu%20versuchen%2C%20die%20CI-Fehlerb%C3%A4nder%20einzuf%C3%BCgen%2C%20um%20zu%20zeigen%2C%20ob%20sie%20sich%20%C3%BCberschneiden%2C%20stellte%20jedoch%20fest%2C%20dass%20das%20aktuelle%20Verhalten%20von%20JMP%20nicht%20wie%20erwartet%20funktioniert.Hier%20sehen%20Sie%2C%20dass%20die%20Fehlerb%C3%A4nder%20nur%20ein%20kleiner%20Streifen%20auf%20der%20linken%20Seite%20des%20Diagramms%20sind.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shampton82_0-1691504047594.jpeg%22%20style%3D%22width%3A%20701px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shampton82_0-1691504047594.jpeg%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shampton82_0-1691504047594.jpeg%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55644iF97185B1E53936F4%2Fimage-dimensions%2F701x385%3Fv%3Dv2%22%20width%3D%22701%22%20height%3D%22385%22%20role%3D%22button%22%20title%3D%22shampton82_0-1691504047594.jpeg%22%20alt%3D%22shampton82_0-1691504047594.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20sich%20w%C3%BCnschen%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIch%20w%C3%BCrde%20gerne%20sehen%2C%20dass%20sich%20die%20Fehlerb%C3%A4nder%20%C3%BCber%20das%20gesamte%20Linienelement%20erstrecken.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shampton82_1-1691504117192.jpeg%22%20style%3D%22width%3A%20637px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shampton82_1-1691504117192.jpeg%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shampton82_1-1691504117192.jpeg%22%20style%3D%22width%3A%20637px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55645i01F7099445E3E7BF%2Fimage-dimensions%2F637x340%3Fv%3Dv2%22%20width%3D%22637%22%20height%3D%22340%22%20role%3D%22button%22%20title%3D%22shampton82_1-1691504117192.jpeg%22%20alt%3D%22shampton82_1-1691504117192.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIch%20k%C3%B6nnte%20es%20so%20aussehen%20lassen%2C%20indem%20ich%20das%20Balkendiagrammelement%20verwende%20und%20die%20Breite%20des%20Balkens%20und%20des%20Bandes%20auf%20100%20festlege%2C%20aber%20es%20sollte%20mir%20nicht%20so%20schwer%20fallen.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EDies%20w%C3%BCrde%20das%20erwartete%20Verhalten%20in%20JMP%20f%C3%BCr%20den%20Benutzer%20standardisieren%20und%20eine%20schnelle%20und%20einfache%20M%C3%B6glichkeit%20bieten%2C%20Gesamtzusammenfassungswerte%20mit%20einem%20bestimmten%20Zeitintervallbereich%20anzuzeigen%2C%20was%20branchen%C3%BCbergreifend%20ein%20Standardwert%20f%C3%BCr%20Berichte%20ist.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-666649%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EDatenexploration%20und%20-visualisierung%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EGrafik%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Graph builder line chart element error bands
I use line charts a lot without using the X element, so that the line goes all the way across the chart and shows some summary value, usually the mean. I started to try and put in the CI error bands to show if they overlap but found that the current behavior of JMP does not work as I expected.  Here you can see the error bands are just a sliver on the left side of the chart.
I would like to see the error bands go all the way across line element.
I could make it look like this by using the bar chart element and making the width of the bar and band=100 but it shouldn’t be that hard in my mind.
Why is this idea important?
This would standardize the expected behavior in JMP for the user as well as provide a quick and easy way to show overall summary values with some time of interval band, which is a standard thing to report out on across all industries.
