Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
