%3CLINGO-SUB%20id%3D%22lingo-sub-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20il%20test%20di%20Friedman%20dovrebbe%20essere%20incluso%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ES%C3%AC%2C%20sono%20le%20cose%20semplici%20che%20sono%20palesemente%20assenti%20e%20allontanano%20JMP%20dall'essere%20del%20tutto%20raccomandabile.%20Sono%20andato%20a%20cercare%20questo%20(o%20un%20equivalente%20cliccabile)%20ed%20%C3%A8%20risultato%20vuoto.%20Sembra%20che%20questo%20sia%20ci%C3%B2%20che%20voglio%20fare%20per%20scenografie%20incomplete%20e%20valori%20di%20ordine%20classificato%2C%20ma%20devo%20fare%20alcune%20trasformazioni%20prima%20delle%20colonne.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EIl%20test%20di%20Friedman%20dovrebbe%20essere%20incluso%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMi%20rendo%20conto%20che%20esiste%20una%20soluzione%20alternativa%20per%20eseguire%20un%20test%20di%20Friedman%2C%20ma%20non%20%C3%A8%20certamente%20una%20grande%20richiesta%20per%20averlo%20nel%20programma.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECi%C3%B2%20%C3%A8%20particolarmente%20vero%20se%20lo%20si%20utilizza%20per%20l'insegnamento.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiche%20e%20analisi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20il%20test%20di%20Friedman%20dovrebbe%20essere%20incluso%20in%20JMP%20-%20Stato%20modificato%20in%3A%20Consegnato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20il%20test%20di%20Friedman%20dovrebbe%20essere%20incluso%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIl%20Friedman%20Rank%20test%20%C3%A8%20disponibile%20in%20Fit%20Y%20by%20X%20nel%20menu%20non%20parametrico.%20Il%20test%20%C3%A8%20disponibile%20solo%20a%20queste%20condizioni%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EC'%C3%A8%20una%20variabile%20di%20blocco.%3C%2FLI%3E%0A%3CLI%3ETutti%20i%20blocchi%20hanno%20pesi%20uguali%20(design%20bilanciato).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3ESe%20queste%20condizioni%20non%20sono%20soddisfatte%2C%20l'opzione%20sar%C3%A0%20disabilitata.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377070%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20il%20test%20di%20Friedman%20dovrebbe%20essere%20incluso%20in%20JMP%20-%20Stato%20modificato%20in%3A%20Consegnato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377070%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
