%3CLINGO-SUB%20id%3D%22lingo-sub-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ELe%20test%20de%20Friedman%20devrait%20%C3%AAtre%20inclus%20dans%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJe%20me%20rends%20compte%20qu'il%20existe%20une%20solution%20de%20contournement%20pour%20faire%20un%20test%20de%20Friedman%2C%20mais%20ce%20n'est%20certainement%20pas%20une%20grande%20demande%20de%20l'avoir%20dans%20le%20programme.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECela%20est%20particuli%C3%A8rement%20vrai%20si%20vous%20l'utilisez%20pour%20l'enseignement.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAnalyse%20et%20mod%C3%A9lisation%20des%20donn%C3%A9es%20de%20base%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Le%20test%20de%20Friedman%20devrait%20%C3%AAtre%20inclus%20dans%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELe%20test%20Friedman%20Rank%20est%20disponible%20dans%20Fit%20Y%20by%20X%20dans%20le%20menu%20non%20param%C3%A9trique.%20Le%20test%20n'est%20disponible%20que%20dans%20ces%20conditions%20%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EIl%20existe%20une%20variable%20bloquante.%3C%2FLI%3E%0A%3CLI%3ETous%20les%20blocs%20ont%20des%20poids%20%C3%A9gaux%20(conception%20%C3%A9quilibr%C3%A9e).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3ESi%20ces%20conditions%20ne%20sont%20pas%20remplies%2C%20l'option%20sera%20d%C3%A9sactiv%C3%A9e.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Le%20test%20de%20Friedman%20devrait%20%C3%AAtre%20inclus%20dans%20JMP%20-%20Statut%20chang%C3%A9%20en%26nbsp%3B%3A%20Livr%C3%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%20%3A%20Le%20test%20de%20Friedman%20devrait%20%C3%AAtre%20inclus%20dans%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EOui%2C%20ce%20sont%20les%20choses%20simples%20qui%20sont%20manifestement%20absentes%20et%20qui%20emp%C3%AAchent%20JMP%20d'%C3%AAtre%20totalement%20recommandable.%20Je%20suis%20all%C3%A9%20chercher%20ceci%20(ou%20un%20%C3%A9quivalent%20cliquable)%20et%20je%20suis%20tomb%C3%A9%20vide.%20Il%20semble%20que%20c'est%20ce%20que%20je%20veux%20faire%20pour%20les%20conceptions%20de%20d%C3%A9cors%20incompl%C3%A8tes%20et%20les%20valeurs%20d'ordre%20class%C3%A9es%2C%20mais%20je%20dois%20d'abord%20effectuer%20quelques%20transformations%20dans%20les%20colonnes.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
