%3CLINGO-SUB%20id%3D%22lingo-sub-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20la%20prueba%20de%20Friedman%20debe%20incluirse%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ES%C3%AD%2C%20son%20las%20cosas%20simples%20las%20que%20est%C3%A1n%20evidentemente%20ausentes%20y%20desv%C3%ADan%20a%20JMP%20de%20ser%20totalmente%20recomendable.%20Fui%20a%20buscar%20esto%20(o%20un%20equivalente%20en%20el%20que%20se%20puede%20hacer%20clic)%20y%20llegu%C3%A9%20vac%C3%ADo.%20Parece%20que%20esto%20es%20lo%20que%20quiero%20hacer%20para%20los%20dise%C3%B1os%20de%20conjuntos%20incompletos%20y%20los%20valores%20de%20orden%20clasificados%2C%20pero%20necesito%20hacer%20algunas%20transformaciones%20primero%20de%20las%20columnas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ELa%20prueba%20de%20Friedman%20debe%20incluirse%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMe%20doy%20cuenta%20de%20que%20hay%20una%20soluci%C3%B3n%20para%20hacer%20una%20prueba%20de%20Friedman%2C%20pero%20ciertamente%20no%20es%20una%20gran%20solicitud%20tenerla%20en%20el%20programa.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EEsto%20es%20especialmente%20cierto%20si%20se%20usa%20para%20ense%C3%B1ar.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EEstad%C3%ADsticas%20y%20anal%C3%ADticas%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20la%20prueba%20de%20Friedman%20debe%20incluirse%20en%20JMP%20-%20Estado%20cambiado%20a%3A%20Entregado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20la%20prueba%20de%20Friedman%20debe%20incluirse%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELa%20prueba%20de%20rango%20de%20Friedman%20est%C3%A1%20disponible%20en%20Ajuste%20Y%20por%20X%20en%20el%20men%C3%BA%20no%20param%C3%A9trico.%20La%20prueba%20solo%20est%C3%A1%20disponible%20en%20estas%20condiciones%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EHay%20una%20variable%20de%20bloqueo.%3C%2FLI%3E%0A%3CLI%3ETodos%20los%20bloques%20tienen%20pesos%20iguales%20(dise%C3%B1o%20equilibrado).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3ESi%20no%20se%20cumplen%20estas%20condiciones%2C%20la%20opci%C3%B3n%20se%20desactivar%C3%A1.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377070%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20la%20prueba%20de%20Friedman%20debe%20incluirse%20en%20JMP%20-%20Estado%20cambiado%20a%3A%20Entregado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377070%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
