%3CLINGO-SUB%20id%3D%22lingo-sub-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EFriedman's%20test%20should%20be%20included%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EI%20realize%20that%20there%20is%20a%20workaround%20for%20doing%20a%20Friedman's%20test%2C%20but%20it%20is%20certainly%20not%20a%20big%20ask%20to%20have%20it%20in%20the%20program.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20is%20especially%20true%20if%20using%20it%20for%20teaching%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistics%20and%20Analytics%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Friedman's%20test%20should%20be%20included%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EThe%20Friedman%20Rank%20test%20is%20available%20in%20Fit%20Y%20by%20X%20under%20the%20nonparametric%20menu.%20The%20test%20is%20only%20available%20under%20these%20conditions%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EThere%20is%20a%20blocking%20variable.%3C%2FLI%3E%0A%3CLI%3EAll%20blocks%20have%20equal%20weights%20(balanced%20design).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EIf%20these%20conditions%20are%20not%20met%2C%20then%20the%20option%20will%20be%20disabled.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Friedman's%20test%20should%20be%20included%20in%20JMP%20-%20Status%20changed%20to%3A%20Delivered%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Friedman's%20test%20should%20be%20included%20in%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EYes%2C%20its%20the%20simple%20things%20that%20are%20glaringly%20absent%20and%20veer%20JMP%20away%20from%20being%20wholly%20recommendable.%20I%20went%20looking%20for%20this%20(or%20a%20clickable%20equivalent)%20and%20came%20empty.%20Seems%20this%20is%20what%20I%20want%20to%20do%20for%20incomplete%20set%20designs%20and%20ranked%20order%20values%20but%20need%20to%20do%20some%20transformations%20first%20of%20the%20columns.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
