%3CLINGO-SUB%20id%3D%22lingo-sub-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EDer%20Friedman-Test%20sollte%20in%20JMP%20enthalten%20sein%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMir%20ist%20klar%2C%20dass%20es%20einen%20Workaround%20f%C3%BCr%20die%20Durchf%C3%BChrung%20eines%20Friedman-Tests%20gibt%2C%20aber%20es%20ist%20sicherlich%20keine%20gro%C3%9Fe%20Herausforderung%2C%20ihn%20im%20Programm%20zu%20haben.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDies%20gilt%20insbesondere%20dann%2C%20wenn%20es%20f%C3%BCr%20den%20Unterricht%20verwendet%20wird.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-271490%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGrundlegende%20Datenanalyse%20und%20Modellierung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Friedmans%20Test%20sollte%20in%20JMP%20enthalten%20sein%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377069%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDer%20Friedman-Rank-Test%20ist%20im%20Men%C3%BC%20%E2%80%9ENichtparametrisch%E2%80%9C%20unter%20%E2%80%9EY%20nach%20X%20anpassen%E2%80%9C%20verf%C3%BCgbar.%20Der%20Test%20ist%20nur%20unter%20diesen%20Bedingungen%20verf%C3%BCgbar%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EEs%20gibt%20eine%20blockierende%20Variable.%3C%2FLI%3E%0A%3CLI%3EAlle%20Bl%C3%B6cke%20haben%20das%20gleiche%20Gewicht%20(ausgewogenes%20Design).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3EWenn%20diese%20Bedingungen%20nicht%20erf%C3%BCllt%20sind%2C%20wird%20die%20Option%20deaktiviert.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Friedmans%20Test%20sollte%20in%20JMP%20enthalten%20sein%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Geliefert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377063%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Friedmans%20Test%20sollte%20in%20JMP%20enthalten%20sein%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-324834%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJa%2C%20es%20sind%20die%20einfachen%20Dinge%2C%20die%20eklatant%20fehlen%20und%20JMP%20davon%20abhalten%2C%20absolut%20empfehlenswert%20zu%20sein.%20Ich%20habe%20danach%20gesucht%20(oder%20ein%20anklickbares%20%C3%84quivalent)%20und%20bin%20leer%20ausgegangen.%20Dies%20scheint%20das%20zu%20sein%2C%20was%20ich%20f%C3%BCr%20unvollst%C3%A4ndige%20B%C3%BChnenbilder%20und%20Rangfolgewerte%20tun%20m%C3%B6chte%2C%20muss%20aber%20zun%C3%A4chst%20einige%20Transformationen%20in%20den%20Spalten%20vornehmen.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Friedman's test should be included in JMP
I realize that there is a workaround for doing a Friedman's test, but it is certainly not a big ask to have it in the program.
This is especially true if using it for teaching .
3 Comments
marxx
Level III
Yes, its the simple things that are glaringly absent and veer JMP away from being wholly recommendable. I went looking for this (or a clickable equivalent) and came empty. Seems this is what I want to do for incomplete set designs and ranked order values but need to do some transformations first of the columns.
mia_stephens
Status changed to: Delivered
mia_stephens
The Friedman Rank test is available in Fit Y by X under the nonparametric menu. The test is only available under these conditions:
  1. There is a blocking variable.
  2. All blocks have equal weights (balanced design).
If these conditions are not met, then the option will be disabled.
