%3CLINGO-SUB%20id%3D%22lingo-sub-342728%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EScalabilit%C3%A0%20della%20dimensione%20del%20carattere%20con%20dimensione%20del%20grafico%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-342728%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EPer%20qualche%20motivo%20il%20carattere%20predefinito%20sulla%20maggior%20parte%20dei%20grafici%20%C3%A8%20impostato%20su%20un%20valore%20molto%20basso%20ed%20%C3%A8%20quasi%20sempre%20impossibile%20da%20leggere.%20Sono%20stato%20in%20grado%20di%20modificare%20l'impostazione%20predefinita%20in%20un%20carattere%20globale%20pi%C3%B9%20grande%2C%20ma%20a%20volte%20questo%20non%20%C3%A8%20appropriato%20e%20ottengo%20un%20testo%20enorme%20sovrapposto%20su%20una%20trama%20relativamente%20piccola.%20Sarebbe%20bello%20se%20ci%20fosse%20una%20sorta%20di%20fattore%20di%20ridimensionamento%20automatico%20che%20potrebbe%20essere%20applicato%20ai%20caratteri%20del%20testo%20a%20seconda%20di%20quanto%20sono%20grandi%20le%20finestre%20della%20trama.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-342728%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EGrafica%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERi%3A%20Scalabilit%C3%A0%20della%20dimensione%20del%20carattere%20con%20dimensione%20di%20stampa%20-%20Stato%20modificato%20in%3A%20Archiviato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EStiamo%20archiviando%20questa%20richiesta.%20Se%20questo%20%C3%A8%20ancora%20importante%2C%20commenta%20con%20ulteriori%20dettagli%20e%20riapriremo.%20Grazie!%3C%2FLINGO-BODY%3E
Font Size Scalability with Plot Size
For some reason the default font on most plots is set super low and is almost always impossible to read. I’ve been able to change the default setting to a larger global font, but sometimes this isn’t appropriate and I get huge text overlaid on top of  a relatively small plot. It would be nice if there was some sort of automatic scaling factor that could be applied to the text fonts depending on how big the plot windows are.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
