%3CLINGO-SUB%20id%3D%22lingo-sub-675284%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EPassen%20Sie%20die%20Lebensdauer%20nach%20X%20an%2C%20kopieren%20Sie%20die%20Ergebnisse%20und%20f%C3%BCgen%20Sie%20sie%20ein%2C%20wenn%20Sie%20den%20individuellen%20Bericht%20mit%20Registerkarten%20verwenden%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-675284%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20diese%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3EBeim%20Kopieren%20und%20Einf%C3%BCgen%20dieser%20Ausgabe%20wie%20im%20Betreff%20beschrieben%20mit%20Enhanced%20Metafile%20waren%20mehrere%20Fenster%20leer.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20sich%20w%C3%BCnschen%3F%3C%2FSTRONG%3ELassen%20Sie%20dies%20entweder%20direkt%20funktionieren%20oder%20schalten%20Sie%20den%20individuellen%20Bericht%20mit%20Registerkarten%20beim%20Kopieren%20und%20Einf%C3%BCgen%20automatisch%20aus.%20Es%20schien%20gut%20zu%20funktionieren%2C%20als%20ich%20dieses%20Kontrollk%C3%A4stchen%20deaktivierte.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3EDer%20Benutzer%20erh%C3%A4lt%20das%2C%20was%20er%20erwartet%2C%20wenn%20er%20diese%20Ergebnisse%20kopiert%20und%20einf%C3%BCgt.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-675284%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EZuverl%C3%A4ssigkeitsanalyse%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Fit Life by X, Copy and Pasting results when using Tabbed Individual Report
What inspired this wish list request? When copy and pasting this output as described in the subject, using Enhanced Metafile, several windows were blank.
What is the improvement you would like to see? Either make this work directly or when copy and pasting automatically turn off the Tabbed Individual Report. It seemed to work fine, when I unchecked this box.
Why is this idea important?  It will give the user what they expect when they copy and paste these results.
1 Comment
peng_liu
This seems like a bug. If you are in US or Canada, please contact support@jmp.com If you are in other areas, please find appropriate contact on this page: https://www.jmp.com/en_us/about/international.html
Thanks!
