%3CLINGO-SUB%20id%3D%22lingo-sub-457294%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EExpand%20the%20scope%20of%20the%20Manage%20spec%20limit%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-457294%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHello%20JMP%20team%2C%3C%2FP%3E%3CP%3EI'd%20like%20to%20have%20the%20%22Manage%20Spec%20Limits%22%20platform%20to%20be%20able%20to%20have%20any%20of%20the%20column%20properties%20as%20an%20input.%26nbsp%3B%20What%20the%20defaults%20are%20would%20be%20controlled%20in%20the%20platform%20preferences%20(and%20would%20be%20the%20current%20selections).%26nbsp%3B%20But%20you%20would%20be%20able%20to%20select%20from%20the%20red%20arrow%20all%20the%20properties%20you%20would%20want%20to%20show%20and%20be%20able%20to%20input%20values%20or%20pull%20from%20a%20reference%20table.%26nbsp%3B%20Also%20could%20you%20add%20in%20an%20optional%20preference%20setting%20so%20that%20regardless%20of%20name%20the%20far%20left%20column%20could%20default%20to%20the%20column%20being%20looked%20up%20against%20in%20the%20reference%20table%3F%26nbsp%3B%20Right%20now%20this%20column%20must%20be%20renamed%20to%20%22Process%22%20for%20the%20table%20to%20reference%20correctly.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20considering%20this%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-457294%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EUser%20Interface%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Expand the scope of the Manage spec limit function
Hello JMP team,
I'd like to have the "Manage Spec Limits" platform to be able to have any of the column properties as an input.  What the defaults are would be controlled in the platform preferences (and would be the current selections).  But you would be able to select from the red arrow all the properties you would want to show and be able to input values or pull from a reference table.  Also could you add in an optional preference setting so that regardless of name the far left column could default to the column being looked up against in the reference table?  Right now this column must be renamed to "Process" for the table to reference correctly.
Thanks for considering this
Steve
