%3CLINGO-SUB%20id%3D%22lingo-sub-218915%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EApertura%20pi%C3%B9%20semplice%20di%20database%20in%20linea%20da%20siti%20web%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-218915%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EA%20meno%20che%20non%20mi%20sia%20perso%20qualche%20aggiornamento%2C%20trovo%20il%20modo%20di%20aprire%20database%20online%20tramite%20API%20estremamente%20goffo%20tramite%20script.%20%3CBR%20%2F%3E%20Quello%20che%20vorrei%20%C3%A8%20la%20possibilit%C3%A0%20di%20navigare%20in%20un%20sito%20Web%20dall'interno%20di%20JMP%20e%20accedere%20al%20db%20e%20JMP%20ricorda%20le%20informazioni%20(genera%20lo%20script%20per%20te)%20da%20eseguire%20su%20altre%20occorrenze.%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-218915%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAccesso%20ai%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-218917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20Apertura%20pi%C3%B9%20semplice%20di%20database%20in%20linea%20da%20siti%20Web%20-%20Stato%20modificato%20in%3A%20Richiede%20informazioni%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-218917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-218916%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Apertura%20pi%C3%B9%20facile%20di%20database%20online%20da%20siti%20web%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-218916%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EGrazie%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5504%22%20target%3D%22_blank%22%3E%20%40d_barnett%20%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPuoi%20fornire%20alcuni%20esempi%20di%20siti%20web%20%2F%20database%20per%20i%20quali%20vorresti%20questo%20tipo%20di%20interattivit%C3%A0%3F%20%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-334151%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Apertura%20pi%C3%B9%20facile%20di%20database%20in%20linea%20da%20siti%20web%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-334151%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F5504%22%20target%3D%22_blank%22%3E%40d_barnett%3C%2FA%3E%20%2C%20puoi%20darci%20qualche%20esempio%20di%20database%20%2F%20siti%20web%20qui%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
Easier Opening of Online Databases from Websites
Unless I've missed some update i find the way of opening online databases via API extremely clunky via scripting.
What I'd like is the ability to navigate to a website from within JMP and login to the db and JMP remembers the information (generates the script for you) to be run on other occurrences.
3 Comments
Jeff_Perkinson
Community Manager
Thanks, @d_barnett.
Can you give some examples of websites/databases that you'd like this kind of interactivity for?
Jeff_Perkinson
Community Manager
Status changed to: Needs Info
Jeff_Perkinson
Community Manager
@d_barnett, can you give us any examples of databases/websites here?
