%3CLINGO-SUB%20id%3D%22lingo-sub-614617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EVergleichstabellen%20mit%20einer%20Schaltfl%C3%A4che%20zum%20Verketten%2C%20um%20eine%20Tabelle%20mit%20%C3%A4hnlichen%20Daten%20hinzuzuf%C3%BCgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-614617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20Sie%20zu%20dieser%20Wunschlistenanfrage%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIch%20habe%20viele%20Dateien%2C%20die%20ich%20zusammenf%C3%BChren%20muss.%20Sie%20sind%20alle%20in%20Excel%20und%20sie%20haben%20die%20gleichen%20Namensspalten%2C%20wenn%20der%20Vergleich%20der%20Tabellen%20eine%20Schaltfl%C3%A4che%20h%C3%A4tte%2C%20k%C3%B6nnte%20dies%20das%20Leben%20erleichtern%2C%20um%20zu%20%C3%BCberpr%C3%BCfen%2C%20ob%20es%20Fehler%20gibt%2C%20oder%20sogar%20die%20M%C3%B6glichkeit%2C%20eine%20passende%20Schaltfl%C3%A4che%20f%C3%BCr%20diejenigen%20zu%20erstellen%2C%20die%20nicht%20gleich%20sind%20Rechtschreibung...Au%C3%9Ferdem%20die%20M%C3%B6glichkeit%2C%20statt%20nur%202%20weitere%20Vergleichstabellen%20hinzuzuf%C3%BCgen.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EDiese%20Verbesserung%20k%C3%B6nnte%20das%20Zusammenf%C3%BChren%20von%20Tabellen%20aus%20verschiedenen%20und%20mehreren%20Dateien%20erleichtern.%20Forschern%20helfen%2C%20eine%20gr%C3%B6%C3%9Fere%20Datenbank%20zu%20erstellen.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-614617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EOrganisation%20von%20Inhalten%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDatenverschmelzung%20und%20-bereinigung%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMassenanpassung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Comparison Tables with a concatenate button to add a table with the similar data
I have many files that I need to merge them. They are all in excel and they have the same name columns if the comparison of the tables had a button this could facilitate the life to check if there are any mistakes or even the possibility to do a matching button for the ones that are not the same spelling...Also, the possibility to add more comparison tables instead of only 2.
This improvement could make it easier merging tables from different files and multiple ones. Helping researchers to do a bigger data bank.
