%3CLINGO-SUB%20id%3D%22lingo-sub-623612%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EConfronto%20di%20pi%C3%B9%20tabelle%20di%20dati%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-623612%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECiao%2C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%C3%88%20possibile%20estendere%20la%20funzionalit%C3%A0%20di%20Confronta%20tabelle%20dati%20per%20consentire%20il%20confronto%20di%20pi%C3%B9%20di%20due%20tabelle%20dati%20alla%20volta%3F%20Nel%20frattempo%2C%20c'%C3%A8%20una%20soluzione%20alternativa%20per%20abilitarlo%3F%20Nel%20mio%20caso%20d'uso%20attuale%2C%20vorrei%20confrontare%20le%20modifiche%20su%20tre%20tabelle%20di%20dati.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EGrazie.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ESaluti%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-623612%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EMiscelazione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-629199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Confronto%20di%20pi%C3%B9%20tabelle%20di%20dati%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-629199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E
Comparing Multiple Data Tables
Hello,
Can the functionality of Compare Data Tables be extended to allow comparison of more than two data tables at a time? In the interim, is there a workaround to enable this? In my current use case, I'd like to compare changes across three data tables.
Thank you.
Regards
Mehul Shroff
1 Comment
