%3CLINGO-SUB%20id%3D%22lingo-sub-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ECancella%20Ricerca%20%2F%20Trova%20%2F%20Sostituisci%20salvati%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EQuando%20usi%3CSTRONG%3E%20Modifica%26gt%3B%20Cerca%26gt%3B%20Trova%3C%2FSTRONG%3E%20o%3CSTRONG%3E%20Modifica%26gt%3B%20Cerca%26gt%3B%20Sostituisci%3C%2FSTRONG%3E%20%2C%20il%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%22%3E%20i%20termini%20di%20ricerca%20e%20%2F%20o%20sostituzione%20utilizzati%20in%20precedenza%20vengono%20memorizzati%20e%20disponibili%20in%20un%20menu%20a%20discesa%20nella%20finestra%20di%20dialogo%20Trova%20%2F%20Sostituisci.Questo%20a%20volte%20pu%C3%B2%20essere%20fastidioso%2C%20ad%20esempio%20quando%20si%20digita%20un%20nuovo%20termine%20di%20ricerca%20che%20inizia%20con%20la%20stessa%20lettera%20di%20un%20termine%20di%20ricerca%20precedente%2C%20ma%20il%20primo%20carattere%20%C3%A8%20una%20diversa%20maiuscola%2C%20cambia%20automaticamente%20il%20primo%20carattere%20nel%20caso%20dei%20termini%20di%20ricerca%20precedenti%20primo%20carattere.Inoltre%2C%20questo%20potrebbe%20essere%20un%20potenziale%20problema%20se%20non%20si%20desidera%20visualizzare%20i%20termini%20di%20ricerca%20precedenti%20per%20motivi%20di%20privacy%20o%20riservatezza.%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESarebbe%20bello%20aggiungere%3A%3C%2FP%3E%3CP%3E1)%20una%20preferenza%20per%20consentire%20di%20non%20memorizzare%20quella%20cronologia%3C%2FP%3E%3CP%3E2)%20un'opzione%20per%20eliminare%20la%20cronologia%20trova%20%2F%20sostituisci%3C%2FP%3E%3CP%3E3)%20un'opzione%20per%20conservare%20ma%20non%20utilizzare%20la%20cronologia%20trova%20%2F%20sostituisci%20nella%20finestra%20di%20dialogo%20Cerca%20%2F%20Sostituisci%3C%2FP%3E%3CP%3E4)%20un'opzione%20per%20non%20sovrascrivere%20il%20caso%20del%20nuovo%20termine%20di%20ricerca%20inserito%20manualmente%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ENon%20penso%20che%20questo%20sia%20nella%20documentazione%20di%20JMP%2C%20ma%20puoi%20rimuovere%20quella%20cronologia%20di%20ricerca%20manualmente%20eliminando%20questo%20file%20in%20Windows%3CBR%20%2F%3E%3CSPAN%3E%20C%3A%20%5C%20Users%20%5C%20%3CUSERID%3E%20%5C%20AppData%20%5C%3C%2FUSERID%3E%3C%2FSPAN%3E%3CSPAN%3E%20Roaming%20%5C%20SAS%20%5C%20JMP%20%5C%2016%20%5C%20FindMRU.txt%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3Ee%20questo%20semplice%20script%20rimuover%C3%A0%20quel%20file%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Enames%20default%20to%20here(1)%3B%0A%0A%2F%2F%20remove%20previous%20search%20and%20replace%20history%0A%0Afname%20%3D%20%22FindMRU.txt%22%3B%0Afpath%20%3D%20Get%20Path%20Variable(%22%24USER_APPDATA%22)%3B%0Aif(File%20Exists(fpath%20%7C%7C%20fname)%2C%0ADelete%20File(fpath%20%7C%7C%20fname)%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20Cancella%20ricerca%2Ftrova%2Fsostituisci%20salvata%20-%20Stato%20cambiato%20in%3A%20Indagine%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Clear saved Search/Find/Replace
When you use Edit > Search > Find or Edit > Search > Replace , the search and/or replace terms you have used previously are stored and available in a drop down in the Find/Replace Dialog.  This can be annoying at times, for instance when typing a new search term that starts with the same letter as a previous search term, but the first character is a different capitalization, it automatically switches the first character to the case of the previous search terms first character.  Also, this could be a potentially an issue if you did not want to display previous search terms for privacy or confidentiality reasons.
It would be nice to add:
1) a preference to allow to not store that history
2) an option to delete the find/replace history
3) an option to retain but not use the find/replace history in the Search/Replace dialog
4) an option to not overwrite the case of new search term that is entered manually
I don't think this is in the JMP Documentation, but you can remove that search history manually by deleting this file in Windows
C:\Users\<UserID>\AppData\Roaming\SAS\JMP\16\FindMRU.txt
and this simple script will remove that file
names default to here(1);
// remove previous search and replace history
fname = "FindMRU.txt";
fpath = Get Path Variable("$USER_APPDATA");
if(File Exists(fpath || fname),
Delete File(fpath || fname)
1 Comment
SamGardner
Level VII
