%3CLINGO-SUB%20id%3D%22lingo-sub-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EEffacer%20la%20recherche%20%2F%20rechercher%20%2F%20remplacer%20enregistr%C3%A9e%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELorsque%20vous%20utilisez%3CSTRONG%3E%20Modifier%26gt%3B%20Rechercher%26gt%3B%20Rechercher%3C%2FSTRONG%3E%20ou%20alors%3CSTRONG%3E%20Edition%26gt%3B%20Rechercher%26gt%3B%20Remplacer%3C%2FSTRONG%3E%20%2C%20les%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%22%3E%20Les%20termes%20de%20recherche%20et%20%2F%20ou%20de%20remplacement%20que%20vous%20avez%20utilis%C3%A9s%20pr%C3%A9c%C3%A9demment%20sont%20stock%C3%A9s%20et%20disponibles%20dans%20une%20liste%20d%C3%A9roulante%20de%20la%20bo%C3%AEte%20de%20dialogue%20Rechercher%20%2F%20Remplacer.Cela%20peut%20parfois%20%C3%AAtre%20ennuyeux%2C%20par%20exemple%20lors%20de%20la%20saisie%20d'un%20nouveau%20terme%20de%20recherche%20qui%20commence%20par%20la%20m%C3%AAme%20lettre%20qu'un%20terme%20de%20recherche%20pr%C3%A9c%C3%A9dent%2C%20mais%20le%20premier%20caract%C3%A8re%20est%20une%20capitalisation%20diff%C3%A9rente%2C%20il%20remplace%20automatiquement%20le%20premier%20caract%C3%A8re%20par%20la%20casse%20des%20termes%20de%20recherche%20pr%C3%A9c%C3%A9dents%20premier%20caract%C3%A8re.En%20outre%2C%20cela%20peut%20poser%20un%20probl%C3%A8me%20si%20vous%20ne%20souhaitez%20pas%20afficher%20les%20termes%20de%20recherche%20pr%C3%A9c%C3%A9dents%20pour%20des%20raisons%20de%20confidentialit%C3%A9%20ou%20de%20confidentialit%C3%A9.%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ECe%20serait%20bien%20d'ajouter%3A%3C%2FP%3E%3CP%3E1)%20une%20pr%C3%A9f%C3%A9rence%20pour%20permettre%20de%20ne%20pas%20stocker%20cet%20historique%3C%2FP%3E%3CP%3E2)%20une%20option%20pour%20supprimer%20l'historique%20de%20recherche%20%2F%20remplacement%3C%2FP%3E%3CP%3E3)%20une%20option%20pour%20conserver%20mais%20ne%20pas%20utiliser%20l'historique%20de%20recherche%20%2F%20remplacement%20dans%20la%20bo%C3%AEte%20de%20dialogue%20Rechercher%20%2F%20Remplacer%3C%2FP%3E%3CP%3E4)%20une%20option%20pour%20ne%20pas%20%C3%A9craser%20la%20casse%20du%20nouveau%20terme%20de%20recherche%20qui%20est%20entr%C3%A9%20manuellement%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJe%20ne%20pense%20pas%20que%20ce%20soit%20dans%20la%20documentation%20JMP%2C%20mais%20vous%20pouvez%20supprimer%20cet%20historique%20de%20recherche%20manuellement%20en%20supprimant%20ce%20fichier%20dans%20Windows%3CBR%20%2F%3E%3CSPAN%3E%20C%3A%20%5C%20Users%20%5C%20%3CUSERID%3E%20%5C%20AppData%20%5C%3C%2FUSERID%3E%3C%2FSPAN%3E%3CSPAN%3E%20Itin%C3%A9rance%20%5C%20SAS%20%5C%20JMP%20%5C%2016%20%5C%20FindMRU.txt%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3Eet%20ce%20simple%20script%20supprimera%20ce%20fichier%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Enames%20default%20to%20here(1)%3B%0A%0A%2F%2F%20remove%20previous%20search%20and%20replace%20history%0A%0Afname%20%3D%20%22FindMRU.txt%22%3B%0Afpath%20%3D%20Get%20Path%20Variable(%22%24USER_APPDATA%22)%3B%0Aif(File%20Exists(fpath%20%7C%7C%20fname)%2C%0ADelete%20File(fpath%20%7C%7C%20fname)%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%26nbsp%3BEffacer%20les%20recherches%2Frechercher%2Fremplacer%20enregistr%C3%A9s%26nbsp%3B%E2%80%93%26nbsp%3BLe%20statut%20a%20%C3%A9t%C3%A9%20remplac%C3%A9%20par%26nbsp%3B%3A%26nbsp%3BEnqu%C3%AAte%20en%20cours%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Clear saved Search/Find/Replace
When you use Edit > Search > Find or Edit > Search > Replace , the search and/or replace terms you have used previously are stored and available in a drop down in the Find/Replace Dialog.  This can be annoying at times, for instance when typing a new search term that starts with the same letter as a previous search term, but the first character is a different capitalization, it automatically switches the first character to the case of the previous search terms first character.  Also, this could be a potentially an issue if you did not want to display previous search terms for privacy or confidentiality reasons.
It would be nice to add:
1) a preference to allow to not store that history
2) an option to delete the find/replace history
3) an option to retain but not use the find/replace history in the Search/Replace dialog
4) an option to not overwrite the case of new search term that is entered manually
I don't think this is in the JMP Documentation, but you can remove that search history manually by deleting this file in Windows
C:\Users\<UserID>\AppData\Roaming\SAS\JMP\16\FindMRU.txt
and this simple script will remove that file
names default to here(1);
// remove previous search and replace history
fname = "FindMRU.txt";
fpath = Get Path Variable("$USER_APPDATA");
if(File Exists(fpath || fname),
Delete File(fpath || fname)
2 Comments
SamGardner
Level VII
