%3CLINGO-SUB%20id%3D%22lingo-sub-386500%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EBorrar%20b%C3%BAsquedas%2Fencontrar%2Freemplazar%20guardadas%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-386500%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3EAl%20usar%20%3CSTRONG%3EEditar%20%26gt%3B%20Buscar%20%26gt%3B%20Buscar%3C%2FSTRONG%3E%20o%20%3CSTRONG%3EEditar%20%26gt%3B%20Buscar%20%26gt%3B%20Reemplazar%3C%2FSTRONG%3E%20%2C%20los%20%3CSPAN%3Et%C3%A9rminos%20de%20b%C3%BAsqueda%20o%20reemplazo%20utilizados%20anteriormente%20se%20almacenan%20y%20est%C3%A1n%20disponibles%20en%20un%20men%C3%BA%20desplegable%20del%20cuadro%20de%20di%C3%A1logo%20Buscar%2FReemplazar.%20Esto%20puede%20resultar%20molesto%20a%20veces%3B%20por%20ejemplo%2C%20al%20escribir%20un%20t%C3%A9rmino%20de%20b%C3%BAsqueda%20que%20empieza%20con%20la%20misma%20letra%20que%20el%20anterior%2C%20pero%20el%20primer%20car%C3%A1cter%20tiene%20una%20may%C3%BAscula%20o%20min%C3%BAscula%20diferente%2C%20se%20cambia%20autom%C3%A1ticamente%20al%20primer%20car%C3%A1cter%20del%20t%C3%A9rmino%20de%20b%C3%BAsqueda%20anterior.%20Adem%C3%A1s%2C%20esto%20podr%C3%ADa%20ser%20un%20problema%20si%20no%20desea%20mostrar%20los%20t%C3%A9rminos%20de%20b%C3%BAsqueda%20anteriores%20por%20motivos%20de%20privacidad%20o%20confidencialidad.%3C%2FSPAN%3E%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3ESer%C3%ADa%20bueno%20agregar%3A%3C%2FP%3E%20%0A%20%20%20%3CP%3E1)%20una%20preferencia%20para%20permitir%20no%20almacenar%20ese%20historial%3C%2FP%3E%20%0A%20%20%20%3CP%3E2)%20una%20opci%C3%B3n%20para%20eliminar%20el%20historial%20de%20b%C3%BAsqueda%20y%20reemplazo%3C%2FP%3E%20%0A%20%20%20%3CP%3E3)%20una%20opci%C3%B3n%20para%20conservar%20pero%20no%20utilizar%20el%20historial%20de%20b%C3%BAsqueda%2Freemplazo%20en%20el%20cuadro%20de%20di%C3%A1logo%20Buscar%2FReemplazar%3C%2FP%3E%20%0A%20%20%20%3CP%3E4)%20una%20opci%C3%B3n%20para%20no%20sobrescribir%20las%20may%C3%BAsculas%20y%20min%C3%BAsculas%20del%20nuevo%20t%C3%A9rmino%20de%20b%C3%BAsqueda%20que%20se%20ingresa%20manualmente%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3ENo%20creo%20que%20esto%20est%C3%A9%20en%20la%20documentaci%C3%B3n%20de%20JMP%2C%20pero%20puedes%20eliminar%20ese%20historial%20de%20b%C3%BAsqueda%20manualmente%20eliminando%20este%20archivo%20en%20Windows.%3CBR%20%2F%3E%20%3CSPAN%3EC%3A%5CUsuarios%5C%3CUSERID%3E%20%5CDatos%20de%20aplicaci%C3%B3n%5C%3C%2FUSERID%3E%3C%2FSPAN%3E%20%3CSPAN%3ERoaming%5CSAS%5CJMP%5C16%5CFindMRU.txt%3C%2FSPAN%3E%3C%2FP%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CP%3E%3CSPAN%3Ey%20este%20sencillo%20script%20eliminar%C3%A1%20ese%20archivo%3C%2FSPAN%3E%3C%2FP%3E%20%0A%20%20%20%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Enames%20default%20to%20here(1)%3B%0A%0A%2F%2F%20remove%20previous%20search%20and%20replace%20history%0A%0Afname%20%3D%20%22FindMRU.txt%22%3B%0Afpath%20%3D%20Get%20Path%20Variable(%22%24USER_APPDATA%22)%3B%0Aif(File%20Exists(fpath%20%7C%7C%20fname)%2C%0ADelete%20File(fpath%20%7C%7C%20fname)%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%20%0A%20%20%20%3CBR%20%2F%3E%20%0A%20%20%20%3CBR%20%2F%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-386500%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3ECombinaci%C3%B3n%20y%20limpieza%20de%20datos%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E%0A%20%0A%3CLINGO-SUB%20id%3D%22lingo-sub-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Borrar%20b%C3%BAsqueda%20guardada%2FBuscar%2FReemplazar%20-%20Estado%20cambiado%20a%3A%20Investigando%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Clear saved Search/Find/Replace
When you use Edit > Search > Find or Edit > Search > Replace , the search and/or replace terms you have used previously are stored and available in a drop down in the Find/Replace Dialog.  This can be annoying at times, for instance when typing a new search term that starts with the same letter as a previous search term, but the first character is a different capitalization, it automatically switches the first character to the case of the previous search terms first character.  Also, this could be a potentially an issue if you did not want to display previous search terms for privacy or confidentiality reasons.
It would be nice to add:
1) a preference to allow to not store that history
2) an option to delete the find/replace history
3) an option to retain but not use the find/replace history in the Search/Replace dialog
4) an option to not overwrite the case of new search term that is entered manually
I don't think this is in the JMP Documentation, but you can remove that search history manually by deleting this file in Windows
C:\Users\<UserID>\AppData\Roaming\SAS\JMP\16\FindMRU.txt
and this simple script will remove that file
names default to here(1);
// remove previous search and replace history
fname = "FindMRU.txt";
fpath = Get Path Variable("$USER_APPDATA");
if(File Exists(fpath || fname),
Delete File(fpath || fname)
2 Comments
SamGardner
Level VII
