%3CLINGO-SUB%20id%3D%22lingo-sub-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EClear%20saved%20Search%2FFind%2FReplace%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EWhen%20you%20use%20%3CSTRONG%3EEdit%20%26gt%3B%20Search%20%26gt%3B%20Find%3C%2FSTRONG%3E%20or%20%3CSTRONG%3EEdit%20%26gt%3B%20Search%20%26gt%3B%20Replace%3C%2FSTRONG%3E%26nbsp%3B%2C%20the%26nbsp%3B%3CSPAN%20style%3D%22font-family%3A%20inherit%3B%22%3Esearch%20and%2For%20replace%20terms%20you%20have%20used%20previously%20are%20stored%20and%20available%20in%20a%20drop%20down%20in%20the%20Find%2FReplace%20Dialog.%26nbsp%3B%20This%20can%20be%20annoying%20at%20times%2C%20for%20instance%20when%20typing%20a%20new%20search%20term%20that%20starts%20with%20the%20same%20letter%20as%20a%20previous%20search%20term%2C%20but%20the%20first%20character%20is%20a%20different%20capitalization%2C%20it%20automatically%20switches%20the%20first%20character%20to%20the%20case%20of%20the%20previous%20search%20terms%20first%20character.%26nbsp%3B%20Also%2C%20this%20could%20be%20a%20potentially%20an%20issue%20if%20you%20did%20not%20want%20to%20display%20previous%20search%20terms%20for%20privacy%20or%20confidentiality%20reasons.%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20would%20be%20nice%20to%20add%3A%3C%2FP%3E%3CP%3E1)%20a%20preference%20to%20allow%20to%20not%20store%20that%20history%3C%2FP%3E%3CP%3E2)%20an%20option%20to%20delete%20the%20find%2Freplace%20history%3C%2FP%3E%3CP%3E3)%20an%20option%20to%20retain%20but%20not%20use%20the%20find%2Freplace%20history%20in%20the%20Search%2FReplace%20dialog%3C%2FP%3E%3CP%3E4)%20an%20option%20to%20not%20overwrite%20the%20case%20of%20new%20search%20term%20that%20is%20entered%20manually%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20don't%20think%20this%20is%20in%20the%20JMP%20Documentation%2C%20but%20you%20can%20remove%20that%20search%20history%20manually%20by%20deleting%20this%20file%20in%20Windows%3CBR%20%2F%3E%3CSPAN%3EC%3A%5CUsers%5C%3CUSERID%3E%5CAppData%5C%3C%2FUSERID%3E%3C%2FSPAN%3E%3CSPAN%3ERoaming%5CSAS%5CJMP%5C16%5CFindMRU.txt%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3Eand%20this%20simple%20script%20will%20remove%20that%20file%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3Enames%20default%20to%20here(1)%3B%0A%0A%2F%2F%20remove%20previous%20search%20and%20replace%20history%0A%0Afname%20%3D%20%22FindMRU.txt%22%3B%0Afpath%20%3D%20Get%20Path%20Variable(%22%24USER_APPDATA%22)%3B%0Aif(File%20Exists(fpath%20%7C%7C%20fname)%2C%0ADelete%20File(fpath%20%7C%7C%20fname)%0A)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-386500%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EUser%20Interface%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Clear%20saved%20Search%2FFind%2FReplace%20-%20Status%20changed%20to%3A%20Investigating%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-668184%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Clear saved Search/Find/Replace
When you use Edit > Search > Find or Edit > Search > Replace , the search and/or replace terms you have used previously are stored and available in a drop down in the Find/Replace Dialog.  This can be annoying at times, for instance when typing a new search term that starts with the same letter as a previous search term, but the first character is a different capitalization, it automatically switches the first character to the case of the previous search terms first character.  Also, this could be a potentially an issue if you did not want to display previous search terms for privacy or confidentiality reasons.
It would be nice to add:
1) a preference to allow to not store that history
2) an option to delete the find/replace history
3) an option to retain but not use the find/replace history in the Search/Replace dialog
4) an option to not overwrite the case of new search term that is entered manually
I don't think this is in the JMP Documentation, but you can remove that search history manually by deleting this file in Windows
C:\Users\<UserID>\AppData\Roaming\SAS\JMP\16\FindMRU.txt
and this simple script will remove that file
names default to here(1);
// remove previous search and replace history
fname = "FindMRU.txt";
fpath = Get Path Variable("$USER_APPDATA");
if(File Exists(fpath || fname),
Delete File(fpath || fname)
1 Comment
SamGardner
Level VII
