Bordered or Higher Contrast Heatmap in Graph Builder
I would like to be able to create a bordered heatmap in Graph Builder.  I find that this helps with refering to the X and Y axis level that the cell in the heat map is for, and what a more refined look.
Here is an example output from JMP:
Here is what is the look I want:
I have also attached the data file I used to make thi graph.
5 Comments
We are adding the ability to customize the line color, style and width around the heatmap cells in JMP 15. This will provide the functionality that you are looking for. Here is an example showing the customize dialog options:
Jeff_Perkinson
Community Manager
MathStatChem
Level VII
The status on this should get changed to "implemented", I think.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
This feature is now available in JMP 15.
hogi
Level XIII
thanks for suggesting.
I use this functionality almost every day
