%3CLINGO-SUB%20id%3D%22lingo-sub-78790%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ECreaci%C3%B3n%20de%20scripts%20para%20el%20generador%20de%20aplicaciones%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-78790%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EEn%20la%20versi%C3%B3n%20actual%20de%20JMP%2C%20si%20bien%20la%20capacidad%20de%20arrastrar%20y%20soltar%20y%20crear%20un%20generador%20de%20aplicaciones%20y%2C%20a%20su%20vez%2C%20un%20panel%20de%20control%20es%20sorprendente%2C%20la%20capacidad%20de%20crear%20un%20script%20equivalente%20o%20administrar%20el%20script%20que%20se%20genera%20es%20terriblemente%20dif%C3%ADcil.%20Solicitar%C3%ADa%20que%20se%20revisaran%20los%20scripts%20del%20generador%20de%20aplicaciones%20y%20del%20panel%20de%20control%20para%20que%20sea%20una%20funci%C3%B3n%20m%C3%A1s%20f%C3%A1cil%20de%20crear%20y%20administrar.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-78790%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAutomatizaci%C3%B3n%20y%20scripting%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Creaci%C3%B3n%20de%20scripts%20para%20el%20generador%20de%20aplicaciones%3A%20el%20estado%20ha%20cambiado%20a%3A%20archivado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEstamos%20archivando%20esta%20solicitud.%20Si%20sigue%20siendo%20importante%2C%20comente%20con%20detalles%20adicionales%20y%20la%20volveremos%20a%20abrir.%20%C2%A1Gracias!%3C%2FLINGO-BODY%3E
Application Builder Scripting
In the current version of JMP, while the ability to drag and drop and build an application builder and in turn a dashboard is amazing, the ability to script an equivalent or manage the script that is generated is terribly hard. I would request that the application builder and dashboard scripting be overhauled to make it a more easier to script/manage feature.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
