%3CLINGO-SUB%20id%3D%22lingo-sub-425601%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERegistrazione%20di%20animazioni%20su%20commutatore%20di%20colonne%20e%20filtro%20dati%20locale.%20Uscita%20in%20GIF.%20Rendere%20disponibile%20su%20MacOS%20una%20funzione%20simile%20offerta%20su%20Windows%20OS.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-425601%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMi%20piacerebbe%20avere%20la%20possibilit%C3%A0%20di%20registrare%20e%20salvare%20una%20gif%20animata%20quando%20si%20utilizza%20il%20filtro%20dati%20locale%20e%20il%20commutatore%20di%20colonne%20su%20Mac%20in%20modo%20simile%20a%20quello%20che%20puoi%20fare%20su%20Windows%20in%20JMP%2016.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-425601%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EOrganizzazione%20dei%20contenuti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECondivisione%20e%20comunicazione%20dei%20risultati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Animation Recording at Column Switcher and Local Data Filter. Output to GIF. Making available at MacOS similar function offered at Window OS.
I would like the ability to record and save an animated gif when using the local data filter and column switcher on mac similar to what you can do on Windows in JMP 16.
