%3CLINGO-SUB%20id%3D%22lingo-sub-379021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EConsenti%20l'utilizzo%20dei%20word%20cloud%20come%20filtri%20di%20selezione%20in%20JMP%20Public%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-379021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EPer%20le%20analisi%20di%20testo%20di%20set%20di%20dati%20con%20un%20numero%20elevato%20di%20record%2C%20il%20comando%20clic%20destro%26gt%3Bseleziona%20record%20nella%20piattaforma%20di%20analisi%20del%20testo%20%C3%A8%20eccezionalmente%20utile.%20Sarebbe%20fantastico%20se%20gli%20utenti%20di%20JMP%20Public%20potessero%20utilizzare%20un%20word%20cloud%20per%20selezionare%20un%20sottoinsieme%20di%20record.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-379021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3ECombinazione%20e%20pulizia%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EModellazione%20predittiva%20e%20machine%20learning%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECondivisione%20e%20comunicazione%20dei%20risultati%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Allow word clouds to be used as selection filters in JMP Public
For text analyses of datasets with a large number of records, the right click>select records command in the Text Analysis platform is exceptionally useful. It would be great if JMP Public users could use a word cloud to select a subset of records.
