%3CLINGO-SUB%20id%3D%22lingo-sub-706866%22%20slang%3D%22fr-FR%22%20mode%3D%22NONE%22%3EAdd%20the%20lower%20and%20upper%20bias%20in%20the%20equivalence%20test%20(as%20on%20minitab)%20because%20JMP%20considers%20a%20deviation%20centered%20on%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-706866%22%20slang%3D%22fr-FR%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3EWhat%20inspired%20this%20wishlist%20request%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20possibility%20of%20doing%20it%20on%20Minitab%20%2F%20Excel%3C%2FP%3E%3CP%3EThe%20fact%20that%20a%20bias%20is%20not%20necessarily%20centered%20on%200%20example%3A%20%5B-1%3B%20%2B2%20%5D%3C%2FP%3E%3CP%3EThat%20the%20calculation%20of%20the%20bias%20confidence%20interval%20involves%20both%20the%20Upper%20Limit%20and%20the%20Lower%20Limit%20of%20the%20bias%20and%20not%20necessarily%20the%20calculated%20delta.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhat%20improvement%20would%20you%20like%20to%20see%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBeing%20able%20to%20have%20the%20possibility%20of%20entering%20both%20limits%20and%20not%20just%20the%20delta%20as%20is%20currently%20the%20case.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhy%20is%20this%20idea%20important%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEssential%20for%20managing%20equivalence%20tests%20whose%20bias%20is%20not%20centered%20on%200%2C%20today%20we%20must%20use%20Excel%20to%20mitigate%20this%20difference%20(JMP%20therefore%20not%20usable).%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-706866%22%20slang%3D%22fr-FR%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EBasic%20Data%20Analysis%20and%20Modeling%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Ajouter dans le test d'équivalence le biais inférieur et supérieur (comme sur minitab) car JMP considère un écart centré sur 0
Qu'est-ce qui a inspiré cette demande de liste de souhaits ?
La possibilité de le faire sur Minitab / Excel
Le fait qu'un biais n'est pas forcément centré sur 0 exemple : [-1 ; +2 ]
Que le calcul de l'intervalle de confiance du biais fait intervenir aussi bien l'Upper Limit que la Lower Limit du biais et pas forcément le delta calculé.
Quelle est l’amélioration que vous souhaiteriez voir ?
Pouvoir avoir la possibilité de saisir les deux limites et non que le delta comme c'est le cas actuellement.
Pourquoi cette idée est-elle importante ?
Indispensable pour la gestion des tests d'équivalence dont le biais n'est pas centré sur 0, aujourd'hui nous devons utiliser Excel pour mitiger cet écart (JMP pas utilisable donc).
