%3CLINGO-SUB%20id%3D%22lingo-sub-459001%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EZus%C3%A4tzliche%20Einstellungsoptionen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-459001%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EHallo%20JMP-Team%2C%3C%2FP%3E%3CP%3EIch%20m%C3%B6chte%20folgende%20%C3%84nderungen%20der%20angebotenen%20Einstellungen%20vorschlagen%3A%3C%2FP%3E%3COL%3E%3CLI%3ELassen%20Sie%20in%20Stilen%20die%20Haupt-%2FNebenrasterlinien%20f%C3%BCr%20die%20Y-Achse%20und%20die%20X-Achse%20aufteilen%2C%20sodass%20sie%20separat%20festgelegt%20werden%20k%C3%B6nnen.%3C%2FLI%3E%3CLI%3EF%C3%BCr%20den%20Graph%20Builder%20k%C3%B6nnen%20Sie%20die%20Anzahl%20der%20X-Gruppierungsbeh%C3%A4lter%20festlegen%20(derzeit%20ist%20der%20Standardwert%205).%3C%2FLI%3E%3CLI%3EF%C3%BCr%20neuronale%20Netze%20m%C3%BCssen%20die%20Standardknoten%20festgelegt%20werden%20(aktuell%20sind%20es%203%20TanH%20auf%20einer%20Ebene).%3C%2FLI%3E%3CLI%3EF%C3%BCr%20Bootstrap%20und%20Boosted%20Forest%20m%C3%BCssen%20alle%20Baumparameter%20in%20den%20Einstellungen%20vorhanden%20sein%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%20%3C%2FP%3E%3CP%3EVielen%20Dank%20f%C3%BCr%20die%20Ber%C3%BCcksichtigung%20dieser%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3ESteve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-459001%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EMassenanpassung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-459433%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Zus%C3%A4tzliche%20Einstellungsoptionen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-459433%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20m%C3%B6chte%20eine%20zus%C3%A4tzliche%20Anfrage%20hinzuf%C3%BCgen%2C%20f%C3%BCr%20den%20Markierungsabschnittsmodus%20k%C3%B6nnen%20mehr%20als%20ein%20Modustyp%20ausgew%C3%A4hlt%20werden%3FSoll%20zum%20Beispiel%20ge%C3%A4ndert%20werden%2C%20dass%20die%20ausgew%C3%A4hlten%20Markierungen%20gro%C3%9F%20und%20die%20nicht%20ausgew%C3%A4hlten%20Markierungen%20ausgeblendet%20werden%3F%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Additional Preference options
Hello JMP team,
I'd like to suggest the following changes to the preferences offered:
  1. In styles, have the Major/Minor grid lines be broken out for the Y axis and X axis, so they can be set separately.
  2. For graph builder be able to set the # of X grouping bins (default is 5 currently)
  3. For neural net be able to set the default nodes (current is 3 TanH one level)
  4. For bootstrap and boosted forest have all the tree parameters in the preferences
Thanks for considering these
Steve
1 Comment
shampton82
Level VII
I'd like to add an additional request, for the marker section mode can more than one type of mode be chosen?  So for example change have the selected marker be large and the unselected markers be faded?
