%3CLINGO-SUB%20id%3D%22lingo-sub-340617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAjoutez%20la%20possibilit%C3%A9%20d'utiliser%20un%20filtre%20de%20donn%C3%A9es%20local%20dans%20Evaluate%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-340617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ECe%20serait%20tr%C3%A8s%20bien%20si%20Evaluate%20Design%20vous%20permettait%20d'utiliser%20un%20filtre%20de%20donn%C3%A9es%20local%20lors%20de%20l'%C3%A9valuation%20d'une%20seule%20conception%20(table%20unique).Les%20cas%20d'utilisation%20sont%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%C3%89valuation%20de%20l'impact%20des%20points%20de%20conception%20perdus%3C%2FLI%3E%3CLI%3EVoir%20rapidement%20l'%C3%A9valuation%20des%20conceptions%20initiales%20et%20ensuite%20augment%C3%A9es.%26nbsp%3B%26nbsp%3B%3C%2FLI%3E%3C%2FUL%3E%3CP%3EJe%20ne%20sugg%C3%A8re%20pas%20que%20vous%20devriez%20pouvoir%20comparer%20les%20conceptions%20de%20cette%20fa%C3%A7on%2C%20ce%20n'est%20que%20pour%20une%20v%C3%A9rification%20rapide%20des%20propri%C3%A9t%C3%A9s%20de%20conception%20pour%20des%20sous-ensembles%20d'une%20table%20de%20conception%20compl%C3%A8te.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-340617%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiques%20et%20analyses%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Ajouter%20la%20possibilit%C3%A9%20d'utiliser%20un%20filtre%20de%20donn%C3%A9es%20local%20dans%20Evaluate%20Design%20-%20Statut%20modifi%C3%A9%20en%20%3A%20Archiv%C3%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENous%20archivons%20cette%20demande.%20Si%20cela%20est%20toujours%20important%2C%20veuillez%20commenter%20avec%20des%20d%C3%A9tails%20suppl%C3%A9mentaires%20et%20nous%20rouvrirons.%20Merci%20!%3C%2FLINGO-BODY%3E
Add the ability to use a local data filter in Evaluate Design
It would be very nice if Evaluate Design allowed you to use a local data filter when evaluate a single design (single table).  The use cases are:
  • Evaluating the impact of lost design point(s)
  • Quickly seeing evaluation of intiial and then subsequent augmented designs.
I'm not suggesting you should be able to compare designs this way, this is only for rapid check of design properties for subsets of a full design table.
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
