%3CLINGO-SUB%20id%3D%22lingo-sub-405021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAjouter%20un%20aper%C3%A7u%20dans%20l'affichage%20de%20la%20jointure%20de%20table%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-405021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJe%20voudrais%20ajouter%20un%20aper%C3%A7u%20dans%20l'affichage%20de%20la%20jointure%20de%20table%20pour%20ne%20pas%20faire%20d'erreurs.%3C%2FP%3E%3CP%3ELa%20fonction%20de%20jointure%20de%20table%20peut%20consommer%20une%20m%C3%A9moire%20%C3%A9norme%2C%20en%20particulier%20lorsque%20nous%20avons%20la%20table%20de%20donn%C3%A9es%20avec%20la%20m%C3%AAme%20valeur%20de%20ligne%20ou%20des%20enregistrements%20manquants.%3C%2FP%3E%3CP%3E(Dans%20ce%20cas%2C%20JMP%20essaie%20d'ajouter%20chaque%20valeur%20de%20ligne%20%C3%A0%20toutes%20les%20valeurs%20correspondantes.)%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJe%20sais%20que%20nous%20pouvons%20le%20faire%20fonctionner%20si%20nous%20cochons%20la%20case%20%22Drop%20multiples%22%2C%20mais%20le%20d%C3%A9butant%20fait%20souvent%20des%20erreurs%20sans%20remarquer%20cette%20fonction.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-405021%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterface%20utilisateur%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Add preview in table join display
I would like to add preview in table join display not to make misstakes.
The table join function can consume huge memory especially when we have the data table with the same row value or missing records.
(In that case, JMP tries to add each row value to all matching values.)
I know we can make it work if we check the box with "Drop multiples", but the beginner often makes mistakes without noticing that function.
Thank you.
1 Comment
hogi
Level XII
JMP17: available now.
