%3CLINGO-SUB%20id%3D%22lingo-sub-577837%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EAgregar%20funci%C3%B3n%20para%20ver%20el%20nombre%20de%20las%20barras%20de%20herramientas%20al%20pasar%20el%20cursor%20sobre%20ellas%20o%20hacer%20clic%20con%20el%20bot%C3%B3n%20derecho%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-577837%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EAgregue%20alguna%20forma%20de%20ver%20f%C3%A1cilmente%20el%20nombre%20de%20las%20barras%20de%20herramientas.%20Actualmente%20creo%20que%20tengo%20barras%20de%20herramientas%20habilitadas%2Fdeshabilitadas%20hasta%20que%20noto%20cu%C3%A1l%20ha%20desaparecido.%20Ser%C3%ADa%20%C3%BAtil%20tener%20el%20nombre%20de%20la%20barra%20de%20herramientas%20visible%2C%20por%20ejemplo%2C%20al%20pasar%20el%20cursor%20sobre%20la%20parte%20de%20reordenamiento%20de%20la%20barra%20de%20herramientas%2C%20de%20manera%20similar%20a%20como%20se%20muestran%20las%20sugerencias%20de%20herramientas%20para%20los%20elementos%20de%20la%20barra%20de%20herramientas.%20O%20tal%20vez%20sea%20suficiente%20resaltar%20el%20nombre%20de%20la%20barra%20de%20herramientas%20si%20se%20presiona%20el%20bot%C3%B3n%20derecho%20sobre%20ella.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jthi_1-1670311776101.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jthi_1-1670311776101.png%22%20style%3D%22width%3A%20203px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47954i3B4920B64FFC5515%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jthi_1-1670311776101.png%22%20alt%3D%22jthi_1-1670311776101.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3EEsto%20todav%C3%ADa%20no%20es%20un%20problema%20real%2C%20pero%20si%20alguna%20vez%20comienzo%20a%20agregar%20muchas%20barras%20de%20herramientas%20a%20JMP%2C%20podr%C3%ADa%20ser%20bastante%20molesto%20no%20poder%20ver%20f%C3%A1cilmente%20el%20nombre%20de%20la%20barra%20de%20herramientas.%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-577837%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPersonalizaci%C3%B3n%20masiva%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-580572%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Agregar%20funci%C3%B3n%20para%20ver%20el%20nombre%20de%20las%20barras%20de%20herramientas%20al%20pasar%20el%20mouse%20por%20encima%20o%20al%20hacer%20clic%20con%20el%20bot%C3%B3n%20derecho%20-%20El%20estado%20cambi%C3%B3%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-580572%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHola%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F14366%22%20target%3D%22_blank%22%3E%20%40jthi%3C%2FA%3E%20%2C%20%C2%A1Gracias%20por%20su%20sugerencia!%20Hemos%20capturado%20su%20solicitud%20y%20la%20tomaremos%20en%20consideraci%C3%B3n.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Add feature to see the name of toolbars on hover over / right-click
Add some way to easily see the name of toolbars. Currently I think I have enable/disable toolbars until I notice which one has disappeared. It would be helpful to have toolbar name visible for example by hovering over the re-order part of toolbar similarly as tool tips are displayed for toolbar items. Or maybe highlighting the toolbar name if right-click is pressed on top of it is enough
This isn't yet a real issue, but if I ever start adding many toolbars to JMP, I could see not easily seeing the toolbar name as a fairly annoying thing.
3 Comments
Hi @jthi, thank you for your suggestion! We have captured your request and will take it under consideration.
We are currently prioritizing this request.
