%3CLINGO-SUB%20id%3D%22lingo-sub-83871%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EMod%C3%A8le%20AFT%20pour%20l'analyse%20de%20la%20survie%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-83871%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELe%20mod%C3%A8le%20de%20temps%20de%20d%C3%A9faillance%20acc%C3%A9l%C3%A9r%C3%A9%20fournit%20une%20alternative%20int%C3%A9ressante%20pour%20l'analyse%20de%20survie%20si%20l'hypoth%C3%A8se%20des%20risques%20proportionnels%20n'est%20pas%20remplie.%3C%2FP%3E%0A%3CP%3EVeuillez%20fournir%20une%20mise%20en%20%C5%93uvre%20similaire%20%C3%A0%20celle%20du%20mod%C3%A8le%20param%C3%A9trique%2C%20par%20exemple%20en%20incluant%20des%20profils%20de%20pr%C3%A9diction.%3C%2FP%3E%0A%3CP%3EWinfried%20Koch%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-83871%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiques%20et%20analyses%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-619720%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20Mod%C3%A8le%20AFT%20pour%20l'analyse%20de%20la%20survie%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-619720%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ED%C3%A9placer%20cela%20%C3%A0%20non%20pr%C3%A9vu%20pour%20le%20moment.%20Sera%20rouvert%20si%20des%20informations%20suppl%C3%A9mentaires%20sont%20fournies%20pour%20aider%20%C3%A0%20mieux%20comprendre%20cette%20demande.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-539240%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%26nbsp%3B%3A%20Mod%C3%A8le%20AFT%20pour%20l'analyse%20de%20la%20survie%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-539240%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESalut%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F1197%22%20target%3D%22_blank%22%3E%20%40dr_winfried_koc%3C%2FA%3E%20%2C%20suite%20%C3%A0%20cette%20demande.%20Pouvez-vous%20s'il%20vous%20pla%C3%AEt%20fournir%20des%20informations%20suppl%C3%A9mentaires%20(voir%20le%20commentaire%20pr%C3%A9c%C3%A9dent)%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-521325%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EObjet%26nbsp%3B%3A%20Mod%C3%A8le%20AFT%20pour%20l'analyse%20de%20la%20survie%26nbsp%3B%E2%80%93%20Statut%20modifi%C3%A9%20en%26nbsp%3B%3A%20Besoin%20d'informations%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-521325%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F1197%22%20target%3D%22_blank%22%3E%40dr_winfried_koc%3C%2FA%3E%20merci%20pour%20cette%20nouvelle%20suggestion%20de%20fonctionnalit%C3%A9.Pourriez-vous%20fournir%20plus%20de%20d%C3%A9tails%20sur%20ce%20que%20vous%20aimeriez%20voir%20et%20pourquoi%20cela%20est%20important%20pour%20vous%26nbsp%3B%3F%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQu'est-ce%20qui%20a%20inspir%C3%A9%20cette%20demande%20de%20liste%20de%20souhaits%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3EVeuillez%20d%C3%A9crire%20le%20probl%C3%A8me%20actuel%20qui%20doit%20%C3%AAtre%20am%C3%A9lior%C3%A9%2C%20ou%20le%20nouveau%20probl%C3%A8me%20%C3%A0%20r%C3%A9soudre%20qui%20n'est%20pas%20facile%20ou%20possible%20en%20ce%20moment.%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EVeuillez%20d%C3%A9crire%20la%20fonctionnalit%C3%A9%20ou%20la%20solution%20nouvelle%20ou%20am%C3%A9lior%C3%A9e%20que%20vous%20aimeriez%20voir.%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3ESi%20vous%20pouvez%20fournir%20une%20maquette%2C%20une%20structure%20filaire%2C%20une%20capture%20d'%C3%A9cran%2C%20des%20exemples%20d'ensembles%20de%20donn%C3%A9es%2C%20des%20scripts%20ou%20d'autres%20documents%20permettant%20de%20d%C3%A9crire%20la%20fonctionnalit%C3%A9%2C%20veuillez%20les%20joindre%20%C3%A0%20cette%20demande.%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EQuelle%20serait%20la%20valeur%20pour%20vous%20et%2Fou%20les%20autres%20utilisateurs%20si%20cette%20nouvelle%20fonctionnalit%C3%A9%20%C3%A9tait%20fournie%26nbsp%3B%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3EToute%20information%20sur%20la%20facilit%C3%A9%20d'utilisation%2C%20le%20gain%20de%20temps%2C%20la%20valeur%20des%20nouvelles%20fonctionnalit%C3%A9s%20serait%20appr%C3%A9ci%C3%A9e.S'il%20s'agit%20d'une%20fonctionnalit%C3%A9%20disponible%20via%20d'autres%20solutions%20logicielles%2C%20veuillez%20d%C3%A9crire%20cet%20outil%20logiciel.%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-619721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ER%C3%A9%3A%20Mod%C3%A8le%20AFT%20pour%20l'analyse%20de%20survie%20-%20Statut%20modifi%C3%A9%20en%20%3A%20Non%20pr%C3%A9vu%20pour%20l'instant%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-619721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E
AFT model for survival analysis
The accelerated failure time model provides an interesting alternative for survival analysis if the proportional hazards assumption is not fulfilled.
Please provide an implementation similar to that of the parametric model e.g. including prediction profiles.
Winfried Koch
4 Comments
SamGardner
Level VII
Status changed to: Needs Info
@dr_winfried_koc thank you for this new feature suggestion.  Could you provide more detail on what you would like to see and why this is important to you?
What inspired this Wish List Request?
Please describe the current issue that needs improvement, or the new problem to be solved that is not easy or possible right now.
Please describe the new or improved feature or solution you would like to see.
If you can provide a mock-up, wireframe, screenshot, example data sets, scripts, or other documents that helps describe feature, please attach to this request.
What would the value be to you and/or other users if this new feature is provided?
Any information on ease of use, time saved, new feature value would be appreciated.  If this is a feature that you have available through other software solutions, please describe that software tool.
mia_stephens
Hi @dr_winfried_koc, following up on this request. Can you please provide additional information (see the previous comment)?
mia_stephens
Moving this to not planned for now. Will re-open if additional information is provided to help better understand this request.
mia_stephens
Status changed to: Not Planned For Now
