JMP Tips
Show the Text Log in the Script Window (Windows)
Display the embedded log to quickly see the results of your changes as you run and develop a script. To open the embedded log, right-click in the Script Editor and select Show Embedded Log. Or, to open the embedded log every time you open the Script Editor, select File > Preferences > Script Editor > Show embedded log on script window open.
Embedded LogEmbedded Log
