JMP Tips
Execute Several Actions (Windows)
To select several commands simultaneously:
  1. In a JMP report, hold down the Alt key and click the red triangle.
  2. The window contains all of the options on the red triangle menu.
  3. Change as many options as you want.
  4. (Optional) To save your changes as preferences, under Platform Preferences, click Save Changes to.
  5. Click OK.
Select Multiple OptionsSelect Multiple Options
