JMP Tips
Customize the Legend in Graph Builder (macOS)
Here are some helpful tips when working with the legend in Graph Builder:
  • Double-click anywhere in the legend to hide or rearrange items.
  • Press Control and click an item in the legend to change its properties.
  • Click an item in the legend to select the corresponding rows in the data table.
Legend Settings WindowLegend Settings Window
Comments
hogi
@ruthhummel , If the GraphBuilder Report contains multiple subplots, how can I identify which legend item belongs to which subplot?
