Purpose
This script takes a repeated measures data table (a table with multiple rows per unit)
and turns it into a data table with 1 row per unit and a Pseudo Failure time.
The original data table must contain:
1) A column that identifies each unit,
2) a variable that measures time (can be use such as miles driven), and 3) a
response column.
Usage
Simply run this script by any one of these methods:
Edit > Run Script
Control-R
Click "Run Script" button in tool bar
//*******************General information
//This script takes a repeated measures data table (a table with multiple rows per unit)
//and turns it into a data table with 1 row per unit and a Pseudo Failure time.
//The original data table must contain:
3) a response column.
//*****************Initial Dialog
//The initial dialog allows you to select the response, time measure
//(can be time or a useage measure such as miles driven), and a unit identifier.
//You may also specify 1 group-by variable. If a
//group by variable is specified, the user can select a different transformation
//for each level of the grouping variable
//The radio box at the lower left allows the user to specify whether the plots
//should display a regression line or connect each point in the series for each
//unit. This affects the display graphs but does not alter how the internal calculations
//are performed
//************************Select Transformation window
//After the initial variables are specified, the script opens a window displaying the
//relationship between the time variable and the response. Transformations for time
//and response can be selected frop the drop-down lists at the side of the
//plots. The plots will update when transformations are
//selected to show the new relationship.
//If a group by variable is specified, there will be a separate plot for each
//level of the grouping variable.
//When the user has found a transformation(s) that causes a linear relationship for
//transformed response vs transformed time, he/she can select
//"Create Pseudo Failure Time Data"
//to create the new data table.
//For more information about the Select Transformation window, select the Help
//button in the dialog box.
//**********************Create Data Table Dialog
//This dialog box allows you to enter the failure threshold,
//specify additional covariates (optional), and specify a column in the data
//table that controls the size of the pseudo failure time.
//The resulting data table will have ONE ROW per Unit ID.
//Details
//Covariates for Failure Model (optional):
// An optional list of covariates to be included in the failure
// time model. These columns are copied from the original data table to the
// Pseudo failure time table. They do not affect calculation
// If there are multiple measures for each covariate, the
// LAST VALUE is included in the final table. At this time, the script does
// not support time-dependent covariates
//Maximum Predicted Time (optional)
// An optional column containing maximum predicted times.
// If the predicted failure time from the linear models is greater
// than the value in this column, the pseudo failure time is the
// maximum predicted time from this column.
//Censoring Column (optional)
// A column in the data table that has a 0 for observations that failed during testing
// and a 1 otherwise. If this column is specified, any unit that has a 1 for this column
// will be considered a "hard failure", and the pseudo failure time will be the time of the
// last measurement taken on this variable.
//Failure Threshold (required)
// The value of the response for which the unit would have been considered Failed.
//***************Details on Inputs, outputs, and internal calculations
//Inputs:
// * Data table, as described in assumptions
// --Will use active table or script will prompt for open
// * Failure Level: damage level at which the component is considered "failed"
// --User will type into a labeled box
// * Censor Time (optional): if predicted time exceedes this time, the component
// should be considered "censored"
// --The data table will have a column with the maximum predicted time
// the user will allow for each unit
// * Transformation of time and/or response
// --User will select from a list
// --User will be shown a plot of transformed and predicted values
// and allowed to change selection
//Outputs:
// * Interactive plot. Allows the user to visually fit
// linear transformation
// * Data table containing the following:
// --a row for each component
// --"Predicted Time": a numeric column containing the predicted failure time
// --a numeric column containing the original failure time
// --"Pseudo Failure Time" a numeric column containing the pseudo failure time.
// This is the time predicted by the linear model or,
// if censoring variables are specified,
// the appropriate time of failure. This variable is based on a formula that
// assigns either the original
// time or the predicted time based on the user's specifications.
// --"Censored" A 0,1 variable indicating if the unit is censored (1) or not
// censored (0). This is the variable that should be specified as the
// censoring variable in the Life Distribution platform or other survival
// model.
// --"Estimate Type": an ordinal colum indicating if the row is censored in
// one of the following ways
// --failed during testing: 0
// (In this case, the modeling time is set to the last time that
// unit was measured).
// --did not fail during testing, and predicted time makes sense: 1
// (pseudo failure time = predicted time)
// --predicted censoring time is longer than the user's specified time: 2
// (in this case, the modeling time is set to the maximum time
// specified by the user)
// --there was only one row for the unit--prediction was impossible: 3
// (in this case, the modeling time is to the last time the unit was measured ).
// --in some cases, the calculation for predicted time will result in a time
// that is too large for JSL to handle. In that case, Pseudo fialure is set to
// the maximum time or to the last time the unit was measured if
// there is no maximum time column
// --covariates from the original data table. There is a dialog that allows the user
// to select covariates that will be used in a later analysis.
// * Time-dependent covariates are NOT SUPPORTED. The last values measured for each
// component appears in the data table.
//Calculations:
// * Linear transformation of the input values
// * Predicted failure time using the linear transformation
// --the model calculates a separate line for each unit
// --the script performs the calculation using JSL's matrix language
//Assumptions:
// * The data table is in the following form:
// --1 row for each measurement on each item (repeated measures)
// --Contains a time column specifiying when each measure was taken
// --Contains a censoring column (0,1) indicating if the component
// failed during testing.
// --If the last measure for the unit has censoring=0,
// the new data table will use the failure time given in the table and not the
// predicted failure time.
// * There is an appropriate linear transformation that works for
// all rows or all rows within a by-group (i.e. we do not have situation
// where some rows require a
// log transformation and others require a power transformation)
//Platforms Used:
// * The Bivariate platform is used to create the plots that allow the user to select
// the appropriate transformation. Fit Each Value is used to allow the user to see the
// if the fit is approximately linear.
