Here are custom map shape files for the States of Brazil. To make these files available for whenever you want to build a geographic map, copy the -Name.jmp and -XY.jmp files to the directory shown below.
- On Windows: C:/Users/<user name>/AppData/Roaming/SAS/JMP/Maps
- On macOS: /Users/<user name>/Library/Application Support/JMP/Maps
Also included in the ZIP file is a demonstration JMP data table. This data table has an embedded script that will generate a geographic map of Brazil.
For more information about custom map shape files, search for the topic “Custom Map Files” in JMP Help.
