JMP On Air
The Prediction Profiler
(view in My Videos)
Learn how to use JMP's Prediction Profiler, a tool that gives you a wealth of information about your model. You'll learn how to use the Prediction Profiler to see how your prediction model changes as you change settings of individual factors; set desirability goals for your response or responses, and find optimal settings for your factors; and so much more.
More information and details on using and interpret models using the prediction profiler
