JMP On Air
The Essentials of Graph Builder
(view in My Videos)
Graph Builder is JMP's interactive, go-to graphing platform that allows you to quickly and easily visualize your data. In this session, Laura Higgins shows you the basics of Graph Builder and how you can use it to power up your data analytic and JMP skills.
Do you want to see more of JMP in Action for yourself check out the JMP Mastering series where where you can attend live webinars and more in depth discussions.
Comments
Will you be sharing how you did the import of Netflix data?  Mine only comes in as 2 columns Title and Date.   Thanks.
Hi @JeremyRouse,
By default you do only get the title and date using Netflix viewing history.
@Laura_Higgins joined the title with previously downloaded IMDB data.
The IMDB data was accessed using JMP's HTTP request.
We will plan a future episode of JMP On Air to demonstrate blending data from multiple disparate data sources, such as, JSON and CSV.
cheers,
Stan
@stan_koprowski
Thanks!  That sounds great.
Jeremy
