julian
Module 2:8 - One Factor Repeated Measures
This module introduces one-factor repeated measures designs, and methods for fitting these models in JMP using both Fit Model (with random effects) and the Full Factorial Repeated Measures ANOVA Add-In that is linked below (which can also be used for these one-way designs).
Youtube Playlist
Wiki Page
Slides (attached below)
JMP data (attached below)
Article Tags
Contributors
