%3CLINGO-SUB%20id%3D%22lingo-sub-30742%22%20slang%3D%22en-US%22%3EVideo%3A%20suddivisione%20dei%20dati%20da%20un%20rapporto%20di%20distribuzione%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30742%22%20slang%3D%22en-US%22%3E%3CP%3ESupponiamo%20che%20tu%20sia%20nella%20piattaforma%20di%20distribuzione%20in%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20e%20hai%20creato%20un%20rapporto%20in%20cui%20desideri%20approfondire.%20Bene%2C%20il%20filtro%20locale%20dei%20dati%20pu%C3%B2%20aiutare%20con%20quello.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMa%20forse%20vuoi%20anche%20condividere%20una%20parte%20dei%20dati%20con%20un%20collega%20e%20non%20solo%20il%20rapporto%20stesso.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQuindi%20come%20lo%20fai%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%C3%88%20possibile%20impostare%20i%20dati%20nel%20report.%20In%20JMP%2C%20puoi%20farlo%20visuallly%20e%20molto%20facilmente%20con%20pochi%20clic.%20Dai%20un'occhiata%20a%20questo%20breve%20video%20del%20mio%20collega%20Ryan%20DeWitt%2C%20che%20dimostra%20il%20sottotitolo%20(e%20menziona%20il%20filtro%20locale)%20utilizzando%20alcuni%20dati%20di%20esempio%20inclusi%20in%20JMP.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGrazie%20per%20la%20visione!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fyoutu.be%2FitZcV8fDSvI%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fyoutu.be%2FitZcV8fDSvI%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIscriviti%20al%20%3CA%20href%3D%22https%3A%2F%2Fwww.youtube.com%2Fuser%2FJMPSoftwareFromSAS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Canale%20JMP%20su%20YouTube%20%3C%2FA%3E%20per%20vedere%20gli%20ultimi%20video.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Video: Subsetting data from a JMP Distribution report
Let's say you are in the Distribution platform in JMP, and you have created a report that you wish to drill down into. Well, the Local Data Filter can help with that.
But perhaps you also want to share a portion of the data with a co-worker, and not just the report itself.
So how do you do that?
You could subset the data in the report. In JMP, you can do that visuallly and very easily with a few clicks. Check out this short video by my co-worker Ryan DeWitt, who demonstrates subsetting (and mentions the Local Data Filter) using some sample data included in JMP.
Thanks for watching!
https://youtu.be/itZcV8fDSvI
Subscribe to the JMP channel on YouTube to see the latest videos.
Article Labels
