It's nearly the end of the year, and we are taking a look at the activity in the JMP User Community. Last time, I shared the top content among Discussions posts. Today, we have list of the most popular JMP add-ins, courtesy of community manager Stan Koprowski.
Never used a JMP add-in? An add-in extends JMP by adding new features, functions and applications. It's a JSL script that you can run from the JMP Add-Ins menu. You can share the add-in with other JMP users, and that's what we are looking at here -- those add-ins shared in the File Exchange in the User Community.
The most popular JMP add-ins, in order of number of downloads, are below. Maybe you will find that you need some of these!
Top 10 Most-Downloaded Add-Ins
Full Factorial Repeated Measures ANOVA Add-In
Statistical Dot Plots for JMP 10
Venn Diagram
Custom Map Creator
Interactive Binning (V2)
Text to Columns, Version 2
Capability animation: standard deviation impact
HTML5 Auto-Publishing
Anderson-Darling Normality Test
Method ComparisonWhile all of these add-ins were submitted by my current or former co-workers, I wanted to give some attention to the top add-ins submitted by those outside our company. A special thanks to you for contributing these add-ins to the User Community!
Top 10 Most-Downloaded Add-Ins by Non-Employees
Add-In: Spatial Data Analysis
JMP Addins for Frequency Analysis and Dual Seasonality Time Series Analysis
ROC-Curve & partial Area Under the Curve Analysis
Model Diagnostics and Transformations
Scoping Design DoE JMP Add-In
Window Manager
Add-In to Explore the Implications of Measurement System Quality (ICC or Intra Class Correlation) an...
Icon Names Addin
Univariate Binning using the Normal Mixtures Distribution
Capability Analysis JMP Add-InI look forward to seeing what new add-ins the JMP users share in 2016!
