%3CLINGO-SUB%20id%3D%22lingo-sub-30674%22%20slang%3D%22en-US%22%3EI%20principali%20componenti%20aggiuntivi%20JMP%20del%202015%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30674%22%20slang%3D%22en-US%22%3E%3CP%3E%C3%88%20quasi%20la%20fine%20dell'anno%20e%20stiamo%20dando%20un'occhiata%20all'attivit%C3%A0%20nel%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fwelcome%22%20target%3D%22_blank%22%3E%20Community%20utente%20JMP%20%3C%2FA%3E%20.%20L'ultima%20volta%2C%20ho%20condiviso%20il%20%3CA%20href%3D%22https%3A%2F%2Fblogs.sas.com%2Fcontent%2Fjmp%2F%3Fp%3D18262%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20contenuti%20migliori%20tra%20i%20post%20di%20discussione%20%3C%2FA%3E%20.%20Oggi%20abbiamo%20la%20lista%20dei%20componenti%20aggiuntivi%20JMP%20pi%C3%B9%20popolari%2C%20per%20gentile%20concessione%20del%20community%20manager%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fpeople%2Fstanley.koprowski1%22%20target%3D%22_blank%22%3E%20Stan%20Koprowski%20%3C%2FA%3E%20.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2015%2F12%2FJMP_addin_top_2015.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22wp-image-18326%20aligncenter%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2015%2F12%2FJMP_addin_top_2015.png%22%20alt%3D%22JMP_addin_top_2015%22%20width%3D%22496%22%20height%3D%22283%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMai%20usato%20a%20%3CSTRONG%3E%20Componente%20aggiuntivo%20JMP%20%3C%2FSTRONG%3E%20%3F%20Si%20estende%20un%20componente%20aggiuntivo%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20aggiungendo%20nuove%20funzionalit%C3%A0%2C%20funzioni%20e%20applicazioni.%20%C3%88%20uno%20script%20JSL%20che%20puoi%20eseguire%20da%20JMP%20%3CSPAN%20class%3D%22command%22%3E%20Componenti%20aggiuntivi%20%3C%2FSPAN%3E%20menu.%20Puoi%20condividere%20il%20componente%20aggiuntivo%20con%20altri%20utenti%20JMP%2C%20ed%20%C3%A8%20quello%20che%20stiamo%20guardando%20qui%20-%20quelli%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fcommunity%2Ffile-exchange%2Faddins%22%20target%3D%22_blank%22%3E%20componenti%20aggiuntivi%20%3C%2FA%3E%20condiviso%20nel%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fcommunity%2Ffile-exchange%22%20target%3D%22_blank%22%3E%20Scambio%20di%20file%20%3C%2FA%3E%20nella%20comunit%C3%A0%20degli%20utenti.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20componenti%20aggiuntivi%20JMP%20pi%C3%B9%20popolari%2C%20in%20ordine%20di%20numero%20di%20download%2C%20sono%20riportati%20di%20seguito.%20Forse%20scoprirai%20che%20ti%20servono%20alcuni%20di%20questi!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1156020023%22%20id%3D%22toc-hId-1161797396%22%3EI%2010%20componenti%20aggiuntivi%20pi%C3%B9%20scaricati%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3COL%3E%3C%2FOL%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6993%22%20target%3D%22_blank%22%3EComponente%20aggiuntivo%20ANOVA%20a%20misure%20ripetute%20con%20fattore%20Factorial%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7098%22%20target%3D%22_blank%22%3EStatistical%20Dot%20Plots%20per%20JMP%2010%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6172%22%20target%3D%22_blank%22%3EDiagramma%20di%20Venn%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6218%22%20target%3D%22_blank%22%3ECreatore%20di%20mappe%20personalizzate%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6237%22%20target%3D%22_blank%22%3EInteractive%20Binning%20(V2)%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6082%22%20target%3D%22_blank%22%3ETesto%20in%20colonne%2C%20versione%202%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6966%22%20target%3D%22_blank%22%3EAnimazione%20di%20capacit%C3%A0%3A%20impatto%20di%20deviazione%20standard%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6118%22%20target%3D%22_blank%22%3EAuto-pubblicazione%20HTML5%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6284%22%20target%3D%22_blank%22%3ETest%20di%20normalit%C3%A0%20di%20Anderson-Darling%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6171%22%20target%3D%22_blank%22%3EMetodo%20di%20confronto%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMentre%20tutti%20questi%20componenti%20aggiuntivi%20sono%20stati%20presentati%20dai%20miei%20colleghi%20attuali%20o%20precedenti%2C%20volevo%20dare%20una%20certa%20attenzione%20ai%20componenti%20aggiuntivi%20principali%20presentati%20da%20coloro%20che%20non%20fanno%20parte%20della%20nostra%20azienda.%20Un%20ringraziamento%20speciale%20a%20te%20per%20aver%20contribuito%20con%20questi%20add-in%20alla%20Community%20degli%20utenti!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2043523704%22%20id%3D%22toc-hId-2049301077%22%3EI%2010%20componenti%20aggiuntivi%20pi%C3%B9%20scaricati%20dai%20non%20dipendenti%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3COL%3E%3C%2FOL%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7331%22%20target%3D%22_blank%22%3EAdd-In%3A%20analisi%20dei%20dati%20spaziali%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6994%22%20target%3D%22_blank%22%3EAddin%20di%20JMP%20per%20analisi%20di%20frequenza%20e%20analisi%20di%20serie%20storica%20a%20doppia%20stagionalit%C3%A0%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7500%22%20target%3D%22_blank%22%3ECurva%20ROC%20e%20area%20parziale%20sotto%20l'analisi%20della%20curva%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6610%22%20target%3D%22_blank%22%3EModello%20Diagnostica%20e%20Trasformazioni%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7435%22%20target%3D%22_blank%22%3EComponente%20aggiuntivo%20JP%20DoP%20di%20Scoping%20Design%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7541%22%20target%3D%22_blank%22%3EWindow%20Manager%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7529%22%20target%3D%22_blank%22%3EAdd-in%20per%20esplorare%20le%20implicazioni%20della%20qualit%C3%A0%20del%20sistema%20di%20misura%20(correlazione%20ICC%20o%20Intra%20Class)%20e%20capacit%C3%A0%20di%20processo%20(Cp)%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-8143%22%20target%3D%22_blank%22%3EIcona%20Nomi%20Addin%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-7584%22%20target%3D%22_blank%22%3ECategorizzazione%20univariata%20utilizzando%20la%20distribuzione%20di%20miscele%20normali%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Fdocs%2FDOC-6288%22%20target%3D%22_blank%22%3EComponente%20aggiuntivo%20JMP%20analisi%20capacit%C3%A0%3C%2FA%3E%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENon%20vedo%20l'ora%20di%20vedere%20quali%20nuovi%20componenti%20aggiuntivi%20gli%20utenti%20di%20JMP%20condividono%20nel%202016!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-36889%22%20slang%3D%22en-US%22%3ERi%3A%20Top%20componenti%20aggiuntivi%20JMP%20del%202015%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-36889%22%20slang%3D%22en-US%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F8168%22%20target%3D%22_blank%22%3E%20%40%20quest74%20%3C%2FA%3E%20%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMi%20dispiace%20che%20tu%20abbia%20delle%20difficolt%C3%A0.%20Ho%20visto%20che%20hai%20postato%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Add-Ins%2FSample-Size-and-Power-for-Testing-Two-Variances%2Ftac-p%2F36883%23M362%22%20target%3D%22_blank%22%3E%20questo%20post%20%3C%2FA%3E%20anche.%20Ripeter%C3%B2%20alcune%20delle%20mie%20risposte%20anche%20qui.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPuoi%20trovare%20componenti%20aggiuntivi%20per%20JMP%20in%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Add-Ins%2Ftkb-p%2Fadd-ins%22%20target%3D%22_self%22%3E%20Componenti%20aggiuntivi%20%3C%2FA%3E%20sezione%20del%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FFile-Exchange%2Fct-p%2FFileExchange%22%20target%3D%22_self%22%3E%20Scambio%20di%20file%20%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EC'%C3%A8%20un%20componente%20aggiuntivo%20per%20il%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Add-Ins%2FAnderson-Darling-Normality-Test%2Fta-p%2F21569%22%20target%3D%22_self%22%3E%20Test%20di%20normalit%C3%A0%20di%20Anderson-Darling%20%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ETroverai%20un%20link%20per%20scaricare%20il%20file%20.jmpaddin%20nella%20parte%20superiore%20di%20quel%20post.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDopo%20il%20download%2C%20quando%20si%20fa%20doppio%20clic%20su%20.jmpaddin%2C%20JMP%20dovrebbe%20aprirsi%20e%20richiedere%20all'utente%20di%20chiedere%20se%20si%20desidera%20installare%20il%20componente%20aggiuntivo.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20style%3D%22width%3A%20381px%3B%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fkvoqx44227.i.lithium.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F5503i4DFCAAE87BC66E97%2Fimage-size%2Fmedium%3Fv%3D1.0%26amp%3Bpx%3D400%22%20alt%3D%22Parallels%20DesktopScreenSnapz019.png%22%20title%3D%22Parallels%20DesktopScreenSnapz019.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDopo%20averlo%20installato%2C%20troverai%20l'opzione%20di%20menu%20nel%20tuo%20menu%20Componenti%20aggiuntivi.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20style%3D%22width%3A%20400px%3B%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fkvoqx44227.i.lithium.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F5504i96920A38174CC8F3%2Fimage-size%2Fmedium%3Fv%3D1.0%26amp%3Bpx%3D400%22%20alt%3D%22Parallels%20DesktopScreenSnapz020.png%22%20title%3D%22Parallels%20DesktopScreenSnapz020.png%22%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-36873%22%20slang%3D%22en-US%22%3ERi%3A%20Top%20componenti%20aggiuntivi%20JMP%20del%202015%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-36873%22%20slang%3D%22en-US%22%3E%3CP%3EBuon%20giorno%20Arati%20Mejdal%2C%3C%2FP%3E%3CP%3EHo%20bisogno%20di%20qualcuno%20che%20mi%20aiuti%20su%20come%20usare%20Add%20Ins.%20Sono%20un%20nuovo%20utente%20JMP.%20Ho%20JMP%2011.%20Vorrei%20usare%20JMP%20add%20in.%20Ma%20non%20so%20come%20iniziare%20e%20cosa%20fare.%20Devo%20fare%20Anderson%20Darling%20Test%20per%20la%20normalit%C3%A0%20e%20molti%20altri.%20%26nbsp%3BTutto%20quello%20che%20so%20%C3%A8%20che%20esiste%20un'opzione%20Add-in%20per%20JMP%20disponibile%20sotto%20View.%20Ma%20quando%20clicco%20su%20di%20esso%20ottengo%20il%20messaggio%20seguente%3A%3C%2FP%3E%3CP%3EComponenti%20aggiuntivi%20registrati%3A%3C%2FP%3E%3CP%3EContattare%20l'assistenza%20tecnica%20JMP%3C%2FP%3E%3CP%3EDi%20seguito%20ho%20fornito%20informazioni%20su%20ID%2C%20cartella%20principale%2C%20versione%2C%20un%20pulsante%20per%20annullare%20la%20registrazione%20e%20un%20sito%20Web%20per%20trovare%20altri%20componenti%20aggiuntivi%20in%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.jmp.com%2Faddins%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20http%3A%2F%2Fwww.jmp.com%2Faddins%20%3C%2FA%3E%20E%20alla%20fine%20un%20pulsante%20OK.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHo%20contattato%20il%20supporto%20tecnico%20JMP%20ma%20hanno%20menzionato%20che%20mi%20sono%20registrato%2C%20devo%20andare%20allo%20scambio%20di%20file%20...%20ecc.%20Non%20capisco.%20Aiuto%20di%20Pls%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
Top JMP add-ins of 2015
It's nearly the end of the year, and we are taking a look at the activity in the JMP User Community. Last time, I shared the top content among Discussions posts. Today, we have list of the most popular JMP add-ins, courtesy of community manager Stan Koprowski.
JMP_addin_top_2015
Never used a JMP add-in? An add-in extends JMP by adding new features, functions and applications. It's a JSL script that you can run from the JMP Add-Ins menu. You can share the add-in with other JMP users, and that's what we are looking at here -- those add-ins shared in the File Exchange in the User Community.
The most popular JMP add-ins, in order of number of downloads, are below. Maybe you will find that you need some of these!
Top 10 Most-Downloaded Add-Ins
  1. Full Factorial Repeated Measures ANOVA Add-In
  2. Statistical Dot Plots for JMP 10
  3. Venn Diagram
  4. Custom Map Creator
  5. Interactive Binning (V2)
  6. Text to Columns, Version 2
  7. Capability animation: standard deviation impact
  8. HTML5 Auto-Publishing
  9. Anderson-Darling Normality Test
  10. Method Comparison
  11. While all of these add-ins were submitted by my current or former co-workers, I wanted to give some attention to the top add-ins submitted by those outside our company. A special thanks to you for contributing these add-ins to the User Community!
    Top 10 Most-Downloaded Add-Ins by Non-Employees
    1. Add-In: Spatial Data Analysis
    2. JMP Addins for Frequency Analysis and Dual Seasonality Time Series Analysis
    3. ROC-Curve & partial Area Under the Curve Analysis
    4. Model Diagnostics and Transformations
    5. Scoping Design DoE JMP Add-In
    6. Window Manager
    7. Add-In to Explore the Implications of Measurement System Quality (ICC or Intra Class Correlation) an...
    8. Icon Names Addin
    9. Univariate Binning using the Normal Mixtures Distribution
    10. Capability Analysis JMP Add-In
    11. I look forward to seeing what new add-ins the JMP users share in 2016!
      Article Labels
      2 Comments
