Top JMP add-ins of 2015
It's nearly the end of the year, and we are taking a look at the activity in the JMP User Community. Last time, I shared the top content among Discussions posts. Today, we have list of the most popular JMP add-ins, courtesy of community manager Stan Koprowski.
JMP_addin_top_2015
Never used a JMP add-in? An add-in extends JMP by adding new features, functions and applications. It's a JSL script that you can run from the JMP Add-Ins menu. You can share the add-in with other JMP users, and that's what we are looking at here -- those add-ins shared in the File Exchange in the User Community.
The most popular JMP add-ins, in order of number of downloads, are below. Maybe you will find that you need some of these!
Top 10 Most-Downloaded Add-Ins
  1. Full Factorial Repeated Measures ANOVA Add-In
  2. Statistical Dot Plots for JMP 10
  3. Venn Diagram
  4. Custom Map Creator
  5. Interactive Binning (V2)
  6. Text to Columns, Version 2
  7. Capability animation: standard deviation impact
  8. HTML5 Auto-Publishing
  9. Anderson-Darling Normality Test
  10. Method Comparison
  11. While all of these add-ins were submitted by my current or former co-workers, I wanted to give some attention to the top add-ins submitted by those outside our company. A special thanks to you for contributing these add-ins to the User Community!
    Top 10 Most-Downloaded Add-Ins by Non-Employees
    1. Add-In: Spatial Data Analysis
    2. JMP Addins for Frequency Analysis and Dual Seasonality Time Series Analysis
    3. ROC-Curve & partial Area Under the Curve Analysis
    4. Model Diagnostics and Transformations
    5. Scoping Design DoE JMP Add-In
    6. Window Manager
    7. Add-In to Explore the Implications of Measurement System Quality (ICC or Intra Class Correlation) an...
    8. Icon Names Addin
    9. Univariate Binning using the Normal Mixtures Distribution
    10. Capability Analysis JMP Add-In
    11. I look forward to seeing what new add-ins the JMP users share in 2016!
      Article Labels
      2 Comments
