Ten great things about JMP 10
Statistical Discovery in JMP 10 - new features in JMP 10With the JMP 10 release right around the corner, you might be asking yourself: What are the latest and greatest features that will available to me when I install this new version? I found myself asking the very same question when I first installed the beta and subsequent early adopter versions while preparing the JMP 10 fact sheet and other JMP 10 product information materials.
I can tell you – this is a big release with many amazing additions that you will find both exciting and useful.  I found it hard to limit the “great things” about JMP 10 to 10 items  – since there are so many new features, improvements and analysis platforms – but “Ten for 10” does have a nice ring to it, so I’m going for it.
Before I start the list, the first thing you’ll notice about this release is just how fast it is. The JMP developers have further optimized support for multi-core CPUs, which make JMP blaze through importing huge data files and working with data once it’s into a JMP table.
I have a proposition for you when you first install JMP 10: Search around your computer and find the largest data set you have and try using the Graph Builder platform to visualize it. You will be amazed how effortlessly JMP creates different visualizations as you drag-and-drop your data into Graph Builder – even if it has tens of millions of records.
  1. The Graph Builder, the revolutionary drag-and-drop, interactive way to build a graphical analysis, has been greatly improved to make visual discovery faster. Icons are now provided to switch between graph types through a dedicated panel. Graph Builder also includes more customizations, and even the ability to launch the Fit Model platform to determine if a trend you see visually is statistically significant.
  2. The Local Data Filter is a data filter that you can add to many platforms that lets you filter and focus on specific categories without disturbing the original data table.
  3. The Column Switcher saves the hassle of having to repeat the same analysis over and over when you have many columns of data that need the same analysis performed on them. It’s easy to interchange columns, even if you have thousands of columns, by just adding the Column Switcher within a platform. The switch can be performed manually by clicking or using the arrow keys, or even animated.
  4. The Control Chart Builder is a drag-and-drop way of building control charts analogous to Graph Builder. The platform automatically configures the control chart depending on the type of data you are looking at. You can also drag grouping or phase variables and get a handle on your process control data very efficiently.
  5. The Reliability Forecast platform lets you analyze warranty return data to create reserve forecasts. It lets you perform what-if analyses adjusting production volume, forecast length and contract terms.
  6. The Reliability Growth platform lets you model the reliability of a single repairable system over time as improvements are incorporated into the design. This platform fits Crow-AMSAA models and also features a useful change point detection fitting procedure that automatically determines when phases of the reliability model have changed.
  7. The Measurements Systems Analysis (MSA) platform provides a method for assessing the variation in your measurement system and gauges. The platform was developed under the guidance of Dr. Don Wheeler and his book:  EMP (Evaluating the Measurement Process) III: Using Imperfect Data. One of the great features in this platform is the ability to use the Shift Detection Profiler to explore the MSA-space and interact with your ability to detect a warning.
  8. The Nonlinear platform has a powerful new way of fitting curved data without the need to pre-impute a formula or starting values. Simply select from one of the models in a rich library, which includes popular bioassay or pharmacokinetic models, and your data is fit automatically.
  9. The Partial Least Squares (PLS) platform has been greatly improved and now includes a richer set of graphs and reports.
  10. The Custom Designer includes numerous important improvements, which let you set up discrete numeric factor roles, and the number of runs is automatically updated when center-point and replicate runs are changed.  In addition to these improvements to Custom Designer, a new Evaluate Design platform lets you evaluate any JMP data table treated as a design, change model and alias terms, and see updated diagnostics.
  11. So, there we have it! Ten great new features in JMP 10 that should make you very excited to get your hands on this release. If you’d like to see a preview of some of these new features and platforms in action – look for a brand new video overview of JMP 10 coming in the near future.
    Article Labels
    Article Tags
    9 Comments
    Visitor
    Enhanced Data Visualization | JMP 10 Video Preview wrote:
    [...] a previous post, I gave a list of 10 great things about the new JMP 10 software that is being released on March 20. As part of the preview for this [...]
    Visitor
    Zeelan wrote:
    Hi Daniel ,
    I am new to JMP blog ,I am from SAS BI background .I would like to know in SAS BI once reports are created its publish in SAS IDP .How JMP +SAS reports are viewed.Can we publish these files in SAS IDP or we require any other tool.
    Thanks,
    Zeelan
    Daniel Valente wrote:
    Hi Zeelan -- your best bet would be to check the SAS support pages at https://support.sas.com/ and submit your question to support@sas.com.
    Visitor
    Zeelan wrote:
    Thanks for suggestion .. I will do that
    Visitor
    Control Chart Builder | JMP 10 Video Preview wrote:
    [...] a previous post, I gave a list of 10 great things about the new JMP 10 software that is being released on March 20. As part of the preview for [...]
    Visitor
    Visitor
    JMP 10 speeds discovery; watch live webcast on March 20 wrote:
    [...] out my colleague Dan Valente's post on 10 great things about JMP 10 for a fuller list of new [...]
    Visitor
    Jeff wrote:
    I have questions about JMP 10s ability to handle large datasets with 10s of millions of records.
    Can you give some idea of the size of the dataset in gigabytes? I am hoping it is 50-100+ gigabytes. Also what are the specs of the computer that you were working on where it was blazing through the graphics/analysis for these datasets - how many CPU cores, 32 or 64 bit, how many gigs of ram, what Operating system.
    Thanks!
    Visitor
    Dan Valente wrote:
    Hi Jeff -
    In JMP, any data set that you open must be able to fit in the available RAM you have on your computer. In general, you are able to open up a data set that is equal in size to half the amount of physical memory in your machine. I can refer you to an article by John Sall in our JMP Foreword magazine, which is available in PDF format. You will find the article on page 3. Sall goes through several large data sets of various sizes and also gives the reader information about the computer hardware that he has used for the analysis, along with some speed metrics.
