SAS Dummy Explains 'Open in JMP' Task in SAS Enterprise Guide
Are you interested in learning more ways to integrate SAS Enterprise Guide and JMP? Chris Hemedinger, author of SAS for Dummies, offers some tips in a recent post to his blog, The SAS Dummy.
He explains the "Open in JMP" task in SAS Enterprise Guide. "This add-in task allows you to select a data set from your PC and open it in JMP as part of your SAS Enterprise Guide process flow," he writes. His blog post will help you download and install the task as well.
Article Labels
Article Tags
