XanGregg
Quantum Random Numbers
A few weeks ago, researchers at Institut Ruđer Bošković in Croatia announced a Quantum Random Bit Generator Service. JMP uses a very good Mersenne Twister psuedo-random number generator, but if you want to play with true random numbers, I've uploaded a JMP data table comparing four generators and including a script to load more quantum random numbers from the on-line generator if you have registered for a username and password from the service. The four generators in the data table are
  • Quantum: true random numbers from a quantum bit generator
  • Twister: the Mersenne Twister generator built into JMP
  • Simple: a low quality Linear Congruence Generator
  • RANDU: a better but flawed LCG used by the IBM/360 mainframes
  • The data table includes 2-D and 3-D lag plots for each generator. Here's the 2-D plot for the quantum generator.
    Lag Plot of Quantum Random Numbers
    Twister looks similar, but Simple shows some artifacts. RANDU looks OK in 2-D, but play around with the 3-D view to see its flaw.
    The data table script to load more quantum random numbers provides a good example of JMP 7's network socket support in JSL, allowing a script to communicate with a web service at a low level.
    Article Labels
    Article Tags
