%3CLINGO-SUB%20id%3D%22lingo-sub-30703%22%20slang%3D%22en-US%22%3EUtilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30703%22%20slang%3D%22en-US%22%3E%3CP%3EEn%202011%2C%20mon%20coll%C3%A8gue%20prof.%20Chris%20Nachtsheim%20et%20moi%20avons%20pr%C3%A9sent%C3%A9%20%3CA%20href%3D%22http%3A%2F%2Fwww.jmp.com%2Fcontent%2Fdam%2Fjmp%2Fdocuments%2Fen%2Fwhite-papers%2Fdsd-with-added-two-level-categorical-factors.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20Mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitifs%20%3C%2FA%3E%20(DSD)%20avec%20un%20papier%20dans%20le%20%3CEM%3E%20Journal%20of%20Quality%20Technology%20%3C%2FEM%3E%20.%20Un%20an%20plus%20tard%2C%20j'ai%20%C3%A9crit%20un%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FJMP-Blog%2FIntroducing-definitive-screening-designs%2Fba-p%2F30075%22%20target%3D%22_blank%22%3E%20JMP%20Blog%20post%20%3C%2FA%3E%20d%C3%A9crivant%20ces%20conceptions%20%C3%A0%20l'aide%20de%20trac%C3%A9s%20de%20cellules%20de%20corr%C3%A9lation.%20Depuis%20leur%20introduction%2C%20les%20DSD%20ont%20trouv%C3%A9%20des%20applications%20dans%20des%20domaines%20aussi%20divers%20que%20la%20fabrication%20de%20peinture%2C%20la%20biotechnologie%2C%20les%20%C3%A9nergies%20vertes%20et%20la%20gravure%20laser.%3C%2FP%3E%0A%3CP%3ELorsqu'une%20nouvelle%20m%C3%A9thodologie%20excitante%20se%20pr%C3%A9sente%2C%20les%20chercheurs%20%C3%A0%20la%20pointe%20de%20la%20technologie%20ont%20naturellement%20tendance%20%C3%A0%20vouloir%20l'essayer.%20Lorsque%20ces%20investigateurs%20rapportent%20des%20r%C3%A9sultats%20positifs%2C%20cela%20encourage%20les%20autres%20%C3%A0%20essayer%20%C3%A9galement%20la%20nouvelle%20m%C3%A9thode.%3C%2FP%3E%0A%3CP%3EJe%20suis%20un%20grand%20fan%20des%20DSD%2C%20bien%20s%C3%BBr%2C%20mais%20en%20tant%20que%20co-inventeur%2C%20je%20me%20sens%20responsable%20vis-%C3%A0-vis%20de%20la%20communaut%C3%A9%20des%20praticiens%20de%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fen_us%2Fapplications%2Fdesign-of-experiments.html%3Futm_campaign%3Daw%26amp%3Butm_source%3Dbl%26amp%3Butm_medium%3Dreferral%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20conception%20d'exp%C3%A9riences%20(DOE)%20%3C%2FA%3E%20%C3%AAtre%20clair%20quant%20%C3%A0%20leur%20utilisation%20pr%C3%A9vue%20et%20%C3%A0%20une%20mauvaise%20utilisation%20possible.%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1156020766%22%20id%3D%22toc-hId-1160878840%22%20id%3D%22toc-hId-1160878840%22%3EAlors%2C%20quand%20devrais-je%20utiliser%20un%20DSD%3F%3C%2FH3%3E%0A%3CP%3EComme%20leur%20nom%20l'indique%2C%20les%20DSD%20s%C3%A9lectionnent%20les%20conceptions.%20Leur%20utilisation%20la%20plus%20appropri%C3%A9e%20se%20situe%20aux%20premiers%20stades%20de%20l'exp%C3%A9rimentation%2C%20lorsqu'il%20existe%20un%20grand%20nombre%20de%20facteurs%20potentiellement%20importants%20pouvant%20affecter%20une%20r%C3%A9ponse%20d'int%C3%A9r%C3%AAt%20et%20lorsque%20l'objectif%20est%20d'identifier%20un%20nombre%20g%C3%A9n%C3%A9ralement%20beaucoup%20plus%20r%C3%A9duit%20de%20facteurs%20tr%C3%A8s%20influents.%3C%2FP%3E%0A%3CP%3ES'agissant%20de%20tests%20de%20d%C3%A9pistage%2C%20je%20n'utiliserais%20un%20DSD%20que%20lorsque%20j'ai%20quatre%20facteurs%20ou%20plus.%20De%20plus%2C%20si%20je%20n'avais%20que%20quatre%20facteurs%20et%20si%20je%20voulais%20utiliser%20un%20DSD%2C%20je%20cr%C3%A9erais%20un%20DSD%20pour%20six%20facteurs%20et%20supprimerais%20les%20deux%20derni%C3%A8res%20colonnes.%20La%20conception%20r%C3%A9sultante%20peut%20s%E2%80%99int%C3%A9grer%20au%20mod%C3%A8le%20quadratique%20complet%20dans%20trois%20des%20quatre%20facteurs.%3C%2FP%3E%0A%3CP%3ELes%20DSD%20fonctionnent%20mieux%20lorsque%20la%20plupart%20des%20facteurs%20sont%20continus.%20En%20effet%2C%20chaque%20facteur%20continu%20comporte%20trois%20niveaux%2C%20ce%20qui%20permet%20%C3%A0%20l%E2%80%99enqu%C3%AAteur%20d%E2%80%99ajuster%20une%20courbe%20plut%C3%B4t%20qu%E2%80%99une%20ligne%20droite%20pour%20chaque%20facteur%20continu.%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-2043524447%22%20id%3D%22toc-hId-2048382521%22%20id%3D%22toc-hId-2048382521%22%3EQuand%20utiliser%20un%20DSD%20est-il%20inappropri%C3%A9%3F%3C%2FH3%3E%0A%3CP%3ECi-dessous%2C%20la%20conception%20optimale%20de%20la%20parcelle%20divis%C3%A9e%20surpasse%20de%20fa%C3%A7on%20spectaculaire%20la%20conception%20de%20tri%20d%C3%A9finitif%20cr%C3%A9%C3%A9e%20en%20triant%20le%20facteur%20difficile%20%C3%A0%20modifier%2C%20wp.%20Voir%20le%20point%204)%20ci-dessous.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3CIMG%20class%3D%22%20wp-image-18888%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2016%2F04%2FSPDvsDSD.jpg%22%20border%3D%220%22%20alt%3D%22Le%20graphique%20montre%20la%20puissance%20comparative%20d'une%20conception%20optimale%20en%20parcelles%20divis%C3%A9es%20par%20rapport%20%C3%A0%20une%20conception%20de%20tri%20d%C3%A9finitif%20cr%C3%A9%C3%A9e%20en%20triant%20le%20facteur%20difficile%20%C3%A0%20modifier.%22%20width%3D%22350%22%20height%3D%22325%22%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E1)%20Quand%20il%20y%20a%20des%20contraintes%20sur%20la%20r%C3%A9gion%20de%20conception%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EUne%20hypoth%C3%A8se%20implicite%20sous-jacente%20%C3%A0%20l'utilisation%20des%20DSD%20est%20qu'il%20est%20possible%20de%20d%C3%A9finir%20les%20niveaux%20de%20tout%20facteur%20ind%C3%A9pendamment%20du%20niveau%20de%20tout%20autre%20facteur.%20Cette%20hypoth%C3%A8se%20est%20viol%C3%A9e%20si%20une%20contrainte%20sur%20la%20r%C3%A9gion%20de%20conception%20rend%20certaines%20combinaisons%20de%20facteurs%20impossibles%20%C3%A0%20r%C3%A9aliser.%20Par%20exemple%2C%20si%20je%20cuisine%20du%20ma%C3%AFs%20souffl%C3%A9%2C%20je%20ne%20souhaite%20pas%20r%C3%A9gler%20la%20puissance%20au%20maximum%20lorsque%20vous%20utilisez%20un%20temps%20de%20cuisson%20long.%20Je%20sais%20que%20si%20je%20fais%20cela%2C%20je%20vais%20me%20retrouver%20avec%20un%20g%C3%A2chis%20carbonis%C3%A9.%3C%2FP%3E%0A%3CP%3EPour%20%C3%A9viter%20de%20tels%20probl%C3%A8mes%2C%20il%20peut%20%C3%AAtre%20tentant%20de%20d%C3%A9finir%20la%20fourchette%20des%20facteurs%20internes%2C%20mais%20cette%20pratique%20r%C3%A9duit%20le%20pouvoir%20de%20la%20DSD%20de%20d%C3%A9tecter%20les%20effets%20actifs.%20Il%20est%20pr%C3%A9f%C3%A9rable%20d%E2%80%99utiliser%20la%20totalit%C3%A9%20de%20la%20r%C3%A9gion%20r%C3%A9alisable%20m%C3%AAme%20si%20sa%20forme%20n%E2%80%99est%20ni%20cubique%20ni%20sph%C3%A9rique.%3C%2FP%3E%0A%3CP%3E%3CEM%3E2)%20Lorsque%20certains%20facteurs%20sont%20des%20ingr%C3%A9dients%20dans%20un%20m%C3%A9lange%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EDe%20m%C3%AAme%2C%20l'utilisation%20d'un%20DSD%20n'est%20pas%20appropri%C3%A9e%20si%20deux%20facteurs%20ou%20plus%20entrent%20dans%20la%20composition%20d'un%20m%C3%A9lange.%20Si%20j'augmente%20le%20pourcentage%20d'un%20ingr%C3%A9dient%2C%20je%20dois%20r%C3%A9duire%20le%20pourcentage%20d'un%20autre%20ingr%C3%A9dient%20afin%20que%20ces%20facteurs%20ne%20puissent%20pas%20varier%20ind%C3%A9pendamment%20de%20leur%20nature%20m%C3%AAme.%3C%2FP%3E%0A%3CP%3E%3CEM%3E3)%20Quand%20il%20y%20a%20des%20facteurs%20cat%C3%A9goriques%20avec%20plus%20de%20deux%20niveaux%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3ELes%20DSD%20peuvent%20g%C3%A9rer%20quelques%20facteurs%20cat%C3%A9goriques%20%C3%A0%20deux%20niveaux%2C%20mais%20si%20la%20plupart%20des%20facteurs%20sont%20cat%C3%A9goriques%2C%20l'utilisation%20d'un%20DSD%20est%20inefficace.%20De%20plus%2C%20les%20DSD%20sont%20g%C3%A9n%C3%A9ralement%20un%20choix%20ind%C3%A9sirable%20si%20les%20facteurs%20cat%C3%A9goriels%20ont%20plus%20de%20deux%20niveaux.%20%3CA%20href%3D%22https%3A%2F%2Fwww.linkedin.com%2Fgroups%2F2235170%2F2235170-6117942669911011329%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20Une%20discussion%20r%C3%A9cente%20dans%20le%20groupe%20LinkedIn%20de%20The%20Design%20of%20Experiment%20(DOE)%20%3C%2FA%3E%20impliqu%C3%A9%20pour%20essayer%20de%20modifier%20un%20DSD%20afin%20de%20prendre%20en%20compte%20un%20facteur%20cat%C3%A9gorique%20%C3%A0%20trois%20niveaux.%20Bien%20que%20cela%20soit%20possible%2C%20il%20a%20%C3%A9t%C3%A9%20n%C3%A9cessaire%20d%E2%80%99utiliser%20l%E2%80%99outil%20de%20conception%20personnalis%C3%A9e%20dans%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fen_us%2Fsoftware%2Fdata-analysis-software.html%3Futm_campaign%3Daw%26amp%3Butm_source%3Dbl%26amp%3Butm_medium%3Dreferral%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20JMP%20%3C%2FA%3E%20traiter%20les%20facteurs%20de%20la%20DSD%20en%20tant%20que%20facteurs%20covariants%20et%20ajouter%20le%20facteur%20cat%C3%A9gorique%20%C3%A0%20trois%20niveaux%20comme%20le%20seul%20facteur%20dont%20les%20niveaux%20sont%20choisis%20par%20l'algorithme%20Custom%20Design.%3C%2FP%3E%0A%3CP%3E%3CEM%3E4)%20Lorsque%20le%20DSD%20est%20ex%C3%A9cut%C3%A9%20comme%20une%20conception%20en%20parcelles%20divis%C3%A9es%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EIl%20est%20%C3%A9galement%20inappropri%C3%A9%20de%20modifier%20un%20DSD%20en%20triant%20les%20param%C3%A8tres%20d'un%20facteur%20afin%20que%20la%20conception%20r%C3%A9sultante%20soit%20une%20conception%20en%20trac%C3%A9s%20divis%C3%A9s.%20Pour%20le%20DSD%20%C3%A0%20six%20facteurs%2C%20le%20facteur%20tri%C3%A9%20n'aurait%20que%20trois%20param%C3%A8tres.%20Il%20y%20aurait%20cinq%20courses%20au%20r%C3%A9glage%20bas%2C%20trois%20au%20milieu%20et%20donner%20des%20courses%20au%20r%C3%A9glage%20haut.%20L'utilisation%20d'une%20telle%20conception%20signifierait%20que%20l'inf%C3%A9rence%20sur%20l'effet%20du%20facteur%20tri%C3%A9%20serait%20statistiquement%20invalide.%3C%2FP%3E%0A%3CP%3E%3CEM%3E5)%20Lorsque%20le%20mod%C3%A8le%20d'int%C3%A9r%C3%AAt%20a%20priori%20a%20des%20effets%20d'ordre%20sup%C3%A9rieur%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EPour%20les%20DSD%2C%20les%20termes%20cubiques%20sont%20confondus%20avec%20les%20effets%20principaux.%20Il%20est%20donc%20impossible%20d'identifier%20un%20effet%20cubique.%3C%2FP%3E%0A%3CP%3ELes%20conceptions%20factorielles%20fractionnaires%20%C3%A0%20deux%20niveaux%20r%C3%A9guli%C3%A8res%20et%20les%20conceptions%20de%20Plackett-Burman%20sont%20%C3%A9galement%20inappropri%C3%A9es%20pour%20la%20plupart%20des%20cas%20ci-dessus.%20Donc%2C%20ils%20ne%20sont%20pas%20une%20alternative%20viable.%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId--1363939168%22%20id%3D%22toc-hId--1359081094%22%20id%3D%22toc-hId--1359081094%22%3EQuelle%20est%20l'alternative%20%C3%A0%20l'utilisation%20d'un%20DSD%20dans%20les%20cas%20ci-dessus%3F%3C%2FH3%3E%0A%3CP%3EPour%20les%20utilisateurs%20de%20%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fen_us%2Fsoftware%2Fdownload-jmp-free-trial.html%3Futm_campaign%3Dtd70114000002KZJq%26amp%3Butm_source%3Dbl%26amp%3Butm_medium%3Dreferral%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3E%20JMP%20%3C%2FA%3E%20%2C%20la%20r%C3%A9ponse%20est%20simple%3A%20utilisez%20l'outil%20de%20conception%20personnalis%C3%A9e.%3C%2FP%3E%0A%3CP%3EL'outil%20de%20conception%20personnalis%C3%A9e%20de%20JMP%20peut%20g%C3%A9n%C3%A9rer%20une%20conception%20con%C3%A7ue%20pour%20prendre%20en%20charge%20toute%20combinaison%20des%20sc%C3%A9narios%20%C3%A9num%C3%A9r%C3%A9s%20ci-dessus.%20Le%20principe%20de%20base%20de%20l'outil%20de%20conception%20personnalis%C3%A9e%20est%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%22Les%20conceptions%20doivent%20correspondre%20au%20probl%C3%A8me%20plut%C3%B4t%20que%20de%20le%20modifier%20pour%20l'adapter%20%C3%A0%20la%20conception.%22%3C%2FBLOCKQUOTE%3E%0A%3CH3%20id%3D%22toc-hId--476435487%22%20id%3D%22toc-hId--471577413%22%20id%3D%22toc-hId--471577413%22%3EDerni%C3%A8res%20pens%C3%A9es%3C%2FH3%3E%0A%3CP%3ELes%20DSD%20sont%20des%20mod%C3%A8les%20extr%C3%AAmement%20utiles%20dans%20les%20sc%C3%A9narios%20pour%20lesquels%20ils%20ont%20%C3%A9t%C3%A9%20cr%C3%A9%C3%A9s.%20En%20tant%20que%20mod%C3%A8les%20de%20criblage%2C%20ils%20pr%C3%A9sentent%20de%20nombreuses%20caract%C3%A9ristiques%20souhaitables%3A%3C%2FP%3E%0A%3CP%3E1)%20Les%20principaux%20effets%20sont%20orthogonaux.%3C%2FP%3E%0A%3CP%3E2)%20Les%20effets%20principaux%20sont%20les%20interactions%20orthogonales%20%C3%A0%20deux%20facteurs%20(2FI)%20et%20quadratiques.%3C%2FP%3E%0A%3CP%3E3)%20Tous%20les%20effets%20quadratiques%20des%20facteurs%20continus%20sont%20estimables.%3C%2FP%3E%0A%3CP%3E4)%20Aucun%202FI%20n'est%20confondu%20avec%20un%20autre%20effet%202FI%20ou%20quadratique%20bien%20qu'ils%20puissent%20%C3%AAtre%20corr%C3%A9l%C3%A9s.%3C%2FP%3E%0A%3CP%3E5)%20Pour%20les%20DSD%20avec%2013%20ex%C3%A9cutions%20ou%20plus%2C%20il%20est%20possible%20d'adapter%20le%20mod%C3%A8le%20quadratique%20complet%20%C3%A0%20n'importe%20quel%20sous-ensemble%20%C3%A0%20trois%20facteurs.%3C%2FP%3E%0A%3CP%3E6)%20Les%20DSD%20peuvent%20prendre%20en%20charge%20quelques%20facteurs%20cat%C3%A9goriques%20ayant%20deux%20niveaux.%3C%2FP%3E%0A%3CP%3E7)%20Le%20blocage%20des%20DSD%20est%20tr%C3%A8s%20flexible.%20S'il%20y%20a%20%3CEM%3E%20m%20%3C%2FEM%3E%20facteurs%2C%20vous%20pouvez%20avoir%20un%20nombre%20quelconque%20de%20blocs%20entre%202%20et%20%3CEM%3E%20m%20%3C%2FEM%3E%20.%3C%2FP%3E%0A%3CP%3E8)%3C%2Fimg%3E%20Les%20DSD%20sont%20peu%20co%C3%BBteux%20%C3%A0%20mettre%20en%20service%20sur%20le%20terrain%20et%20ne%20n%C3%A9cessitent%20qu'un%20minimum%20de%202%20%3CEM%3E%20m%20%3C%2FEM%3E%20%2B1%20pistes.%3C%2FP%3E%0A%3CP%3E9)%20Vous%20pouvez%20ajouter%20des%20analyses%20%C3%A0%20un%20DSD%20en%20cr%C3%A9ant%20un%20DSD%20avec%20plus%20de%20facteurs%20que%20n%C3%A9cessaire%20et%20en%20supprimant%20les%20facteurs%20suppl%C3%A9mentaires.%20La%20conception%20r%C3%A9sultante%20a%20les%20sept%20premi%C3%A8res%20propri%C3%A9t%C3%A9s%20ci-dessus%20et%20a%20plus%20de%20puissance%2C%20ainsi%20que%20la%20possibilit%C3%A9%20d'identifier%20plus%20d'effets%20de%20second%20ordre.%3C%2FP%3E%0A%3CP%3E%C3%80%20mon%20avis%2C%20les%20caract%C3%A9ristiques%20ci-dessus%20font%20des%20DSD%20le%20meilleur%20choix%20pour%20toute%20exp%C3%A9rience%20de%20d%C3%A9pistage%20dans%20laquelle%20la%20plupart%20des%20facteurs%20sont%20continus.%3C%2FP%3E%0A%3CP%3ECependant%2C%20je%20tiens%20%C3%A0%20pr%C3%A9ciser%20que%20l'utilisation%20d'un%20%3CEM%3E%20DSD%20n'est%20pas%20une%20panac%C3%A9e%20%3C%2FEM%3E%20.%20En%20d'autres%20termes%2C%20un%20DSD%20n'est%20pas%20la%20solution%20%C3%A0%20tous%20les%20probl%C3%A8mes%20de%20conception%20exp%C3%A9rimentale.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-30703%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20454px%3B%22%3E%3CIMG%20src%3D%22https%3A%2F%2Fkvoqx44227.i.lithium.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F5917i9A24DA636A864F82%2Fimage-size%2Flarge%3Fv%3D1.0%26amp%3Bpx%3D999%22%20alt%3D%22SPDvsDSD.jpg%22%20title%3D%22SPDvsDSD.jpg%22%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%20Je%20suis%20un%20grand%20fan%20des%20DSD%2C%20mais%20en%20tant%20que%20co-inventeur%2C%20je%20me%20sens%20responsable%20%3C%2FSPAN%3E%3CSPAN%3E%20%C3%AAtre%20clair%20quant%20%C3%A0%20leur%20utilisation%20pr%C3%A9vue%20et%20%C3%A0%20une%20mauvaise%20utilisation%20possible.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-54018%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-54018%22%20slang%3D%22en-US%22%3E%3CP%3EDr.%20Jones%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJ'utilise%20DSD%20depuis%20un%20certain%20temps%2C%20avec%20un%20certain%20succ%C3%A8s.%20Cependant%2C%20je%20cherche%20maintenant%20%C3%A0%20utiliser%20DSD%20pour%20les%20r%C3%A9ponses%20binaires%20(croissance%20%2F%20absence%20de%20croissance).%20Cela%20peut-il%20%C3%AAtre%20fait%20avec%20DSD%20et%20comment%20analyseriez-vous%20la%20r%C3%A9ponse%2C%20puisqu'elle%20n'est%20pas%20int%C3%A9gr%C3%A9e%20%C3%A0%20l'algorithme%20d'analyse%20DSD%2C%20je%20suppose%3F%20Ou%20utiliseriez-vous%20d'autres%20types%20de%20conceptions%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMeilleur%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEwoud%20Schuring%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51740%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51740%22%20slang%3D%22en-US%22%3E%3CP%3EDr%20Jones%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci%20pour%20vos%20r%C3%A9ponses%20approfondies%20et%20r%C3%A9fl%C3%A9chies.%20%26nbsp%3BJ'appr%C3%A9cie%20votre%20temps%20et%20votre%20consid%C3%A9ration.%20%26nbsp%3BJe%20vais%20continuer%20la%20discussion%20directement%20avec%20vous.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%C3%80%20votre%20sant%C3%A9%2C%3C%2FP%3E%3CP%3EFacture%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51717%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51717%22%20slang%3D%22en-US%22%3E%3CP%3EDr.%20Ross%20-%20Je%20suis%20tr%C3%A8s%20impressionn%C3%A9%20par%20vos%2016%20000%20exp%C3%A9riences%20DOE.%20Merci%20pour%20votre%20utilisation%20%C3%A0%20long%20terme%20de%20JMP.%20Vous%20%C3%AAtes%20un%20JMPer%20depuis%20plus%20longtemps%20que%20moi!%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EJ'aborde%20ci-dessous%20vos%20cinq%20s%C3%A9ries%20de%20questions%20et%20pr%C3%A9occupations.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1)%20Vous%20indiquez%20que%20les%20exp%C3%A9rimentateurs%20d%C3%A9butants%20ont%20tendance%20%C3%A0%20fixer%20les%20niveaux%20de%20facteurs%20continus%20trop%20proches%20les%20uns%20des%20autres.%20J'ai%20vu%20ce%20comportement%20aussi.%20Je%20crois%20que%20les%20ing%C3%A9nieurs%20pensent%20que%20le%20monde%20est%20non%20lin%C3%A9aire.%20Ils%20savent%20aussi%20par%20le%20calcul%20que%20l'%C3%A9cart%20par%20rapport%20%C3%A0%20la%20lin%C3%A9arit%C3%A9%20est%20faible%20si%20le%20changement%20est%20%C3%A9galement%20faible.%20Le%20probl%C3%A8me%20est%20que%20lorsque%20les%20changements%20dans%20un%20facteur%20sont%20faibles%2C%20le%20bruit%20dans%20la%20r%C3%A9ponse%20peut%20se%20propager%20en%20un%20bruit%20plus%20important%20dans%20la%20pente%20estim%C3%A9e%20de%20la%20ligne%2C%20rendant%20difficile%20l'identification%20des%20facteurs%20actifs.%20Ainsi%2C%20en%20enseignant%20DOE%2C%20nous%20encourageons%20les%20%C3%A9tudiants%20%C3%A0%20faire%20preuve%20d'audace%20en%20faisant%20varier%20les%20facteurs%20continus.%20Je%20pense%20que%20le%20fait%20de%20disposer%20de%20valeurs%20faibles%2C%20moyennes%20et%20%C3%A9lev%C3%A9es%20pour%20chaque%20facteur%2C%20telles%20que%20fournies%20par%20les%20DSD%2C%20peut%20donner%20aux%20ing%C3%A9nieurs%20plus%20de%20confiance%20pour%20r%C3%A9partir%20les%20niveaux%20des%20facteurs.%20En%20effet%2C%20le%20DSD%20peut%20d%C3%A9tecter%20une%20forte%20courbure%20si%20elle%20existe%2C%20ce%20qui%20%C3%A9vite%20les%20soucis%20de%20non-lin%C3%A9arit%C3%A9.%3C%2FP%3E%0A%3CP%3E2%20Je%20mentionne%20dans%20mon%20blog%20ci-dessus%20que%20les%20DSD%20sont%20des%20conceptions%20de%20d%C3%A9pistage%20appropri%C3%A9es%20lorsque%20la%20plupart%20des%20facteurs%20sont%20continus.%20Je%20serais%20r%C3%A9ticent%20%C3%A0%20utiliser%20un%20DSD%20quand%20il%20y%20a%20plus%20de%20trois%20facteurs%20cat%C3%A9goriques%20%C3%A0%20deux%20niveaux.%20Lorsque%20la%20plupart%20des%20facteurs%2C%20voire%20tous%2C%20sont%20cat%C3%A9goriques%20%C3%A0%20deux%20niveaux%2C%20je%20recommanderais%20les%20conceptions%20de%20repli%20efficaces.%20Voici%20la%20r%C3%A9f%C3%A9rence%20%C3%A0%20l'article%20sur%20ces%20dessins.%26nbsp%3B%26nbsp%3BAnna%20Errore%2C%20Bradley%20Jones%2C%20William%20Li%20et%20Christopher%20J.%20Nachtsheim%20(2017)%20Avantages%20et%20construction%20rapide%20de%20conceptions%20de%20repli%20efficaces%20%C3%A0%20deux%20niveaux%2C%20%3CEM%3E%20Technom%C3%A9trie%20%3C%2FEM%3E%20%2C%2059%3A%201%2C%2048-57%2C%20DOI%3A%2010.1080%20%2F%2000401706.2015.1124052%3C%2FP%3E%0A%3CP%3EJe%20pense%20%C3%A9galement%20que%20les%20enqu%C3%AAteurs%20pourraient%20s%E2%80%99efforcer%20davantage%20de%20proposer%20des%20mesures%20quantitatives%20d%C3%A9crivant%20la%20diff%C3%A9rence%20entre%20les%20deux%20niveaux%20d%E2%80%99un%20facteur%20cat%C3%A9gorique%2C%20transformant%20ainsi%20avec%20succ%C3%A8s%20un%20facteur%20cat%C3%A9gorique%20en%20un%20facteur%20continu%20plus%20significatif.%3C%2FP%3E%0A%3CP%3E3%20Vous%20soutenez%20que%20les%20points%20centraux%20peuvent%20d%C3%A9tecter%20la%20courbure.%20Cela%20est%20vrai%2C%20mais%20ils%20ne%20peuvent%20pas%20identifier%20le%20ou%20les%20facteurs%20responsables%20de%20la%20courbure.%20Cette%20ambigu%C3%AFt%C3%A9%20oblige%20%C3%A0%20des%20exp%C3%A9riences%20ult%C3%A9rieures%2C%20ce%20qui%20est%20inutile%20si%20un%20DSD%20est%20utilis%C3%A9.%20J'ai%20vu%20une%20%C3%A9tude%20de%20cas%20o%C3%B9%20un%20puissant%20effet%20quadratique%20avait%20son%20minimum%20dans%20la%20r%C3%A9gion%20d'exp%C3%A9rimentation.%26nbsp%3BUne%20r%C3%A9ponse%20minimale%20%C3%A9tait%20souhaitable%20et%20la%20solution%20id%C3%A9ale%20ici%20serait%20ind%C3%A9tectable%20avec%20une%20conception%20%C3%A0%20deux%20niveaux.%20Une%20autre%20%C3%A9tude%20de%20cas%20a%20r%C3%A9v%C3%A9l%C3%A9%20un%20effet%20quadratique%20important%20dans%20lequel%20la%20r%C3%A9ponse%20maximale%20se%20situait%20dans%20la%20zone%20d%E2%80%99exp%C3%A9rimentation.%26nbsp%3BIci%20%3CSPAN%3E%20%2C%20une%20%3C%2FSPAN%3E%3CSPAN%3E%20une%20r%C3%A9ponse%20maximale%20%C3%A9tait%20souhaitable%20et%2C%20l%C3%A0%20encore%2C%20la%20solution%20id%C3%A9ale%20serait%20ind%C3%A9tectable%20avec%20une%20conception%20%C3%A0%20deux%20niveaux.%20Le%20co%C3%BBt%20pour%20inclure%20la%20possibilit%C3%A9%20d'estimer%20tous%20les%20effets%20quadratiques%20dans%20un%20DSD%20est%20une%20augmentation%20de%2010%25%20(ou%20moins)%20de%20la%20longueur%20des%20intervalles%20de%20confiance%20des%20effets%20principaux.%20Cela%20semble%20un%20petit%20prix%20%C3%A0%20payer%20pour%20le%20gain%20d%E2%80%99information%20sur%20les%20effets%20de%20second%20ordre.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E4%20Vous%20soulignez%2C%20%C3%A0%20juste%20titre%2C%20que%20l%E2%80%99identification%20de%20la%20source%20de%20bruit%20peut%20parfois%20%C3%AAtre%20plus%20importante%20que%20l%E2%80%99estimation%20des%20effets%20fixes.%20Dans%20de%20tels%20cas%2C%20il%20est%20utile%20de%20reproduire%20les%20points%20de%20conception%20afin%20de%20pouvoir%20identifier%20un%20facteur%20affectant%20la%20variance%20de%20la%20r%C3%A9ponse%20tout%20en%20%C3%A9valuant%20simultan%C3%A9ment%20les%20effets%20des%20facteurs%20sur%20la%20r%C3%A9ponse%20moyenne.%20On%20pourrait%20reproduire%20un%20DSD%20entier%20au%20prix%20d'environ%20quatre%20fois%20plus%20d'essais%20que%20de%20facteurs.%20Vous%20mentionnez%20le%20blocage%20dans%20ce%20point.%20Le%20blocage%20peut%20identifier%20et%20quantifier%20une%20source%20de%20variabilit%C3%A9%20et%20supprimer%20son%20effet%20de%20la%20variation%20terme%20%C3%A0%20poste.%20Lorsque%20vous%20modifiez%20les%20conditions%20environnementales%2C%20introduisez%20du%20bruit%20dans%20les%20r%C3%A9ponses%2C%20le%20blocage%20est%20un%20rem%C3%A8de%20utile.%20Les%20DSD%20peuvent%20%C3%AAtre%20bloqu%C3%A9s%20de%20mani%C3%A8re%20plus%20flexible%20que%20les%20conceptions%20factorielles%20fractionnaires%20%C3%A0%20deux%20niveaux%20ou%20factorielles%20compl%C3%A8tes.%20Vous%20trouverez%20ci-dessous%20une%20r%C3%A9f%C3%A9rence%20%C3%A0%20un%20article%20d%C3%A9crivant%20comment%20bloquer%20des%20DSD.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3BBradley%20Jones%20et%20Christopher%20J.%20Nachtsheim%20(2015)%3A%20Syst%C3%A8mes%20de%20blocage%20pour%20les%20conceptions%20de%20d%C3%A9pistage%20d%C3%A9finitif%2C%20%3CEM%3E%20Technom%C3%A9trie%20%3C%2FEM%3E%20%2C%20DOI%3A%2010.1080%20%2F%2000401706.2015.1013777%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E5%20Votre%20derni%C3%A8re%20pr%C3%A9occupation%20concerne%20l%E2%80%99enseignement%20des%20DSD%20et%20une%20approche%20it%C3%A9rative%20de%20l%E2%80%99exp%C3%A9rimentation.%20Je%20ne%20pr%C3%A9sente%20pas%20les%20DSD%20comme%20des%20exp%C3%A9riences%20%22uniques%22.%20Il%20est%20vrai%20que%20la%20structure%20de%20repliement%20des%20plans%20factoriels%20fractionnaires%20traditionnels%20est%20simple%20et%20assez%20facile%20%C3%A0%20expliquer.%20Cependant%2C%20leur%20alias%20complet%20d'effets%20potentiellement%20importants%20n'est%20pas%20souhaitable%20%C3%A0%20mon%20avis.%20Voir%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3BBradley%20Jones%20(2016)%20Exp%C3%A9riences%20de%20d%C3%A9pistage%20au%20XXIe%20si%C3%A8cle%3A%20quoi%2C%20pourquoi%20et%20comment%20%3CEM%3E%20Ing%C3%A9nierie%20de%20la%20qualit%C3%A9%20%3C%2FEM%3E%20%2C%2028%3A%201%2C%2098-106%2C%20DOI%3A%2010.1080%20%2F%2008982112.2015.1100462%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EL'article%20ci-dessus%20%C3%A9tait%20un%20document%20de%20discussion%20avec%20trois%20intervenants.%20Ma%20r%C3%A9plique%20traitait%20de%20nombreuses%20questions%2C%20dont%20la%20conception%20s%C3%A9quentielle%20suite%20%C3%A0%20une%20%C3%A9tude%20initiale%20de%20DSD%20-%20voir%20ci-dessous.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3BBradley%20Jones%20(2016)%20R%C3%A9plique%2C%20%3CEM%3E%20Ing%C3%A9nierie%20de%20la%20qualit%C3%A9%20%3C%2FEM%3E%20%2C%2028%3A%201%2C%20122-126%2C%20DOI%3A%2010.1080%20%2F%2008982112.2015.1100468%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELa%20r%C3%A9f%C3%A9rence%20ci-dessous%20traite%20de%20l%E2%80%99avantage%20relatif%20de%20l%E2%80%99utilisation%20d%E2%80%99un%20DSD%20initial%20m%C3%AAme%20lorsque%20la%20r%C3%A9ponse%20optimale%20pr%C3%A9dite%20est%20en%20dehors%20de%20la%20r%C3%A9gion%20d%E2%80%99exp%C3%A9rimentation.%20Il%20fournit%20%C3%A9galement%20une%20approche%20de%20conception%20de%20suivi%20puissante%20qui%20effectue%20la%20plus%20forte%20ascension.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChristopher%20J.%20Nachtsheim%20%26amp%3B%20Bradley%20Jones%20(2018)%20Augmentation%20de%20la%20conception%20pour%20l'optimisation%20de%20la%20r%C3%A9ponse%20et%20l'estimation%20du%20mod%C3%A8le%2C%20%3CEM%3E%20Ing%C3%A9nierie%20de%20la%20qualit%C3%A9%20%3C%2FEM%3E%20%2C%2030%3A%201%2C%2038-51%2C%20DOI%3A%2010.1080%20%2F%2008982112.2017.1382298%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJe%20ne%20pense%20pas%20qu'il%20soit%20n%C3%A9cessaire%20d'enseigner%20%C3%A0%20un%20praticien%20comment%20cr%C3%A9er%20un%20DSD.%20Beaucoup%20de%20logiciels%20peuvent%20le%20faire.%20Je%20pense%20qu'il%20est%20utile%20de%20familiariser%20les%20enqu%C3%AAteurs%20avec%20le%20diagramme%20de%20cellules%20de%20corr%C3%A9lation.%20JMP%20fournit%20de%20nombreux%20outils%20de%20diagnostic%20pour%20%C3%A9valuer%20et%20comparer%20les%20conceptions.%20Ceux-ci%20sont%20tr%C3%A8s%20utiles%20et%20leur%20utilisation%20dans%20des%20cours%20brefs%20et%20des%20cours%20universitaires%20profiterait%20%C3%A0%20la%20communaut%C3%A9%20des%20praticiens%20du%20DOE.%20Il%20est%20utile%20que%20les%20praticiens%20sachent%20comment%20tirer%20parti%20de%20la%20g%C3%A9om%C3%A9trie%20sp%C3%A9ciale%20d%E2%80%99un%20DSD%20pour%20s%E2%80%99adapter%20aux%20mod%C3%A8les%20appropri%C3%A9s.%20Ceci%20est%20abord%C3%A9%20dans%20la%20r%C3%A9f%C3%A9rence%20ci-dessous.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3BBradley%20Jones%20et%20Christopher%20J.%20Nachtsheim%20(2016)%3A%20S%C3%A9lection%20efficace%20de%20mod%C3%A8les%20bas%C3%A9s%20sur%20la%20conception%20pour%20les%20conceptions%20de%20criblage%20d%C3%A9finitifs%2C%20%3CEM%3E%20Technom%C3%A9trie%20%3C%2FEM%3E%20%2C%20DOI%3A%2010.1080%20%2F%2000401706.2016.1234979%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJe%20serais%20heureux%20de%20poursuivre%20cette%20conversation%20et%20de%20vous%20envoyer%20des%20fichiers%20PDF%20des%20r%C3%A9f%C3%A9rences.%20Vous%20pouvez%20me%20contacter%20%C3%A0%20bradley.jones%40jmp.com%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51478%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51478%22%20slang%3D%22en-US%22%3E%3CP%3EDocteur%20Jones%2C%20je%20suis%20un%20utilisateur%20de%20longue%20date%20de%20JMP%20(depuis%20la%20premi%C3%A8re%20version)%20et%20souhaite%20vous%20remercier%20pour%20vos%20contributions%20%C3%A0%20l'industrie.%20%26nbsp%3B%20J'ai%20particip%C3%A9%20%C3%A0%20la%20conception%20et%20%C3%A0%20l'analyse%20de%20plus%20de%2016%20000%20exp%C3%A9riences%20dans%20de%20nombreux%20secteurs.%20%26nbsp%3BPeut-%C3%AAtre%20que%20ce%20n'est%20pas%20le%20bon%20forum%2C%20mais%20j'ai%20quelques%20questions%20%2F%20commentaires%20(j'esp%C3%A8re%20ne%20pas%20offenser)%2C%20et%20j'appr%C3%A9cierais%20vos%20opinions.%3C%2FP%3E%3CP%3E1.%20Lorsqu'il%20s'agit%20de%20s%C3%A9lectionner%20des%20conceptions%2C%20l'un%20des%20modes%20d'%C3%A9chec%20les%20plus%20courants%20(en%20particulier%20pour%20les%20exp%C3%A9rimentateurs%20d%C3%A9butants)%20est%20celui%20des%20niveaux%20qui%20ne%20sont%20pas%20assez%20%C3%A9loign%C3%A9s%20(assez%20gras).%20%26nbsp%3BLeurs%20effets%20ne%20sont%20donc%20pas%20r%C3%A9alis%C3%A9s%20et%20ces%20facteurs%20peuvent%20m%C3%AAme%20%C3%AAtre%20abandonn%C3%A9s%20(les%20ing%C3%A9nieurs%20h%C3%A9sitent%20%C3%A0%20cr%C3%A9er%20trop%20de%20variations%2C%20ils%20recherchent%20toujours%20la%20solution%20plut%C3%B4t%20que%20de%20comprendre%20les%20relations%20causales).%20%26nbsp%3BIl%20me%20semble%20que%20l'augmentation%20du%20nombre%20de%20niveaux%20%C3%A0%20trois%20complique%20davantage%20ce%20mode%20d'%C3%A9chec%3F%3C%2FP%3E%3CP%3E2%20Au%20d%C3%A9but%20de%20la%20conception%2C%20bon%20nombre%20de%20facteurs%20sont%20qualitatifs.%20%26nbsp%3BIl%20semble%20que%20la%20restriction%20d'ajouter%20trop%20de%20facteurs%20qualitatifs%20%C3%A0%20la%20conception%20est%20un%20fardeau.%20%26nbsp%3BPeut-%C3%AAtre%20que%20cette%20strat%C3%A9gie%20est%20plus%20applicable%20comme%20une%20derni%C3%A8re%20it%C3%A9ration%20dans%20une%20%C3%A9tude%20s%C3%A9quentielle%3F%3C%2FP%3E%3CP%3E3%20Les%20conceptions%20de%20d%C3%A9pistage%20ont%20souvent%20pour%20but%20de%20d%C3%A9terminer%20la%20direction%20%C3%A0%20suivre%20et%20d%E2%80%99%C3%A9liminer%20par%20filtrage%20les%20facteurs%20non%20significatifs%2C%20voire%20plus%20susceptibles%20d%E2%80%99identifier%20des%20facteurs%20importants%20%C3%A0%20%C3%A9tudier%20ult%C3%A9rieurement.%20Les%20%C3%A9quations%20du%20second%20degr%C3%A9%20sont-elles%20vraiment%20n%C3%A9cessaires%20pour%20accomplir%20cela%3F%20D'accord%2C%20je%20suppose%20qu'il%20peut%20arriver%20que%20les%20niveaux%20soient%20trop%20audacieux%20et%20que%20des%20effets%20importants%20soient%20omis%2C%20mais%20que%20l'on%20pourrait%20y%20rem%C3%A9dier%20assez%20facilement%20avec%20des%20points%20centraux.%20%26nbsp%3BSi%20le%20quadratique%20est%20essentiellement%20le%20point%20de%20d%C3%A9part%20du%20lin%C3%A9aire%2C%20si%20vous%20%C3%AAtes%20dans%20un%20espace%20de%20conception%20assez%20%C3%A9loign%C3%A9%20de%20l'optimum%2C%20ne%20seriez-vous%20pas%20plus%20int%C3%A9ress%C3%A9%20par%20l'effet%20lin%C3%A9aire%20en%20premier%3F%20L'%C3%A9quation%20quadratique%20%C3%A0%20la%20base%20de%20la%20montagne%20peut%20ne%20pas%20vous%20mener%20au%20sommet%20de%20la%20montagne.%3C%2FP%3E%3CP%3E4%20De%20plus%2C%20et%20peut-%C3%AAtre%20plus%20important%20encore%2C%20la%20strat%C3%A9gie%20de%20gestion%20du%20bruit%20peut%20%C3%AAtre%20plus%20importante%20que%20la%20r%C3%A9solution%20des%20facteurs%20de%20conception%20(comme%20vous%20le%20savez%2C%20la%20lutte%20constante%20pour%20une%20utilisation%20efficace%20des%20ressources%20entre%20la%20r%C3%A9solution%20du%20facteur%20de%20conception%20et%20la%20r%C3%A9solution%20des%20effets%20de%20bruit).%20%26nbsp%3BSi%20une%20conception%20de%20bloc%20complet%20randomis%C3%A9%20(RCBD)%20est%20utilis%C3%A9e%2C%20avons-nous%20vraiment%20besoin%20de%20certaines%20des%20interactions%20d'ordre%20sup%C3%A9rieur%20bloc%20par%20effet%3F%20Si%20une%20conception%20de%20bloc%20incomplet%20%C3%A9quilibr%C3%A9%20est%20utilis%C3%A9e%2C%20est-il%20facile%20de%20comprendre%20le%20cr%C3%A9nelage%3F%3C%2FP%3E%3CP%3E5%20%26nbsp%3BEnfin%2C%20et%20peut-%C3%AAtre%20de%20moindre%20importance%20pour%20le%20praticien%2C%20comment%20enseigne-t-on%20les%20DSD%3F%20L'utilisation%20de%20conceptions%20factorielles%20fractionnaires%20traditionnelles%20avec%20un%20alias%20identifiable%20et%20des%20id%C3%A9es%20telles%20que%20le%20repliement%20vers%20le%20d%C3%A9saliasage%20est%20simple.%20%26nbsp%3BInsertion%20de%20la%20mentalit%C3%A9%20et%20de%20la%20pratique%20de%20l'it%C3%A9ration%20est%20primordiale.%20%26nbsp%3BComment%20les%20DSD%20s'int%C3%A8grent-ils%20dans%20une%20approche%20it%C3%A9rative%20et%20scientifique%20de%20l'exp%C3%A9rimentation%3F%3C%2FP%3E%3CP%3EJe%20vous%20remercie%20d'avance%20pour%20vos%20pens%C3%A9es.%3C%2FP%3E%3CP%3ESi%20vous%20pr%C3%A9f%C3%A9rez%20prendre%20cette%20discussion%20en%20diff%C3%A9r%C3%A9%2C%20cela%20me%20convient%20parfaitement.%20%26nbsp%3BVous%20pouvez%20m'envoyer%20un%20email%20directement%20%C3%A0%20statman%20%C3%A0%20comcast%20dot%20net%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%C3%80%20votre%20sant%C3%A9%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EBill%20Ross%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-51015%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-51015%22%20slang%3D%22en-US%22%3E%3CP%3EMerci%20Brad%2C%20le%20message%20informatif%20et%20les%20bonnes%20r%C3%A9ponses%20m'ont%20aid%C3%A9%20%C3%A0%20en%20apprendre%20beaucoup%20plus%20sur%20les%20DSD.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-46527%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-46527%22%20slang%3D%22en-US%22%3E%3CP%3EMerci%20Dr.%20Jones%20-%20Ce%20num%C3%A9ro%20n'est%20pas%20encore%20disponible%20sur%20le%20site%20ASQ%20Technometrics.%26nbsp%3B%20Je%20chercherai%20la%20publication%20prochaine.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ERichard%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-46508%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-46508%22%20slang%3D%22en-US%22%3E%3CP%3E%3CA%20title%3D%22S%C3%A9lection%20efficace%20du%20mod%C3%A8le%20bas%C3%A9%20sur%20la%20conception%20pour%20les%20conceptions%20de%20s%C3%A9lection%20d%C3%A9finitives%22%20href%3D%22http%3A%2F%2Fdx.doi.org%2F10.1080%2F00401706.2016.1234979%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fdx.doi.org%2F10.1080%2F00401706.2016.1234979%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ECi-dessus%2C%20l'URL%20d'un%20article%20de%20Technourrics%2C%20paru%20dans%20la%20revue%2C%20par%20Chris%20Nachtsheim%20et%20moi-m%C3%AAme%2C%20intitul%C3%A9e%20S%C3%A9lection%20effective%20du%20mod%C3%A8le%20bas%C3%A9%20sur%20le%20design%20pour%20les%20designs%20de%20criblage%20d%C3%A9finitifs.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECe%20document%20fournit%20une%20forte%20motivation%20pour%20l%E2%80%99ajout%20de%20ce%20que%20nous%20appelons%20des%20%22facteurs%20factices%22%20(c%E2%80%99est-%C3%A0-dire%20des%20facteurs%20utilis%C3%A9s%20dans%20la%20cr%C3%A9ation%20de%20la%20conception%20mais%20non%20utilis%C3%A9s%20lors%20de%20l%E2%80%99ex%C3%A9cution%20de%20l%E2%80%99exp%C3%A9rience.%20Dans%20JMP%2013%2C%20l%E2%80%99outil%20de%20conception%20DSD%20appelle%20cela%20%22Extra%20Runs%22%20avec%20une%20valeur%20par%20d%C3%A9faut%20de%204.%20Cependant%2C%20vous%20pouvez%20remettre%20ce%20champ%20%C3%A0%200%20pour%20obtenir%20le%20minimum%20d'ex%C3%A9cution%20DSD.%20L'ajout%20de%20ces%20ex%C3%A9cutions%20suppl%C3%A9mentaires%20permet%20une%20approche%20analytique%20alternative%20puissante.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-46494%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-46494%22%20slang%3D%22en-US%22%3E%3CP%3EExiste-t-il%20des%20exemples%20publi%C3%A9s%20dans%20lesquels%20des%20colonnes%20ont%20%C3%A9t%C3%A9%20supprim%C3%A9es%2C%20comme%20indiqu%C3%A9%20ci-dessous%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CEM%3ESi%20au%20lieu%20de%20cela%20vous%20utilisiez%20le%20DSD%20%C3%A0%208%20facteurs%20et%20ignoriez%20les%203%20derni%C3%A8res%20colonnes%2C%20vous%20auriez%20un%20plan%20de%2017%20ex%C3%A9cutions%20et%20vous%20devriez%20pouvoir%20identifier%20quatre%20ou%20cinq%20effets%20de%20second%20ordre.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-42911%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-42911%22%20slang%3D%22en-US%22%3E%3CP%3ELes%20DSD%20peuvent%20certainement%20avoir%20des%20probl%C3%A8mes%20quand%20il%20y%20a%20trop%20de%20facteurs%20et%20d'interactions!%20J'en%20ai%20essay%C3%A9%20un%20dans%20un%20syst%C3%A8me%20catalytique%20qui%20avait%20connu%20plusieurs%20g%C3%A9n%C3%A9rations%20d'optimisation%20et%20de%20nombreux%20composants%20et%20interactions%20fonctionnels%20du%20catalyseur.%20J'ai%20fini%20par%20devoir%20ajouter%20quelques%20pistes.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-37974%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20correcte%20et%20inappropri%C3%A9e%20des%20mod%C3%A8les%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-37974%22%20slang%3D%22en-US%22%3E%3CP%3ESuper%20article.%20Cependant%2C%20j'ai%20une%20question%20qui%20me%20laisse%20perplexe.%20Vous%20mentionnez%20que%20vous%20pouvez%20facilement%20ajouter%20des%20ex%C3%A9cutions%20suppl%C3%A9mentaires%20en%20prenant%20une%20hauteur%20sup%C3%A9rieure%20et%20en%20supprimant%20les%20colonnes%20suppl%C3%A9mentaires.%20Je%20me%20demandais%20s'il%20existait%20un%20moyen%20facile%20de%20%22joindre%22%20le%20design.%20Par%20exemple%2C%20j%E2%80%99ai%20fait%20am%20%3D%205%20ex%C3%A9cutions%20DSD%2C%20puis%20j%E2%80%99ai%20d%C3%A9cid%C3%A9%20que%20j%E2%80%99aurais%20besoin%20de%20plus%20de%20puissance%20et%20que%20j%E2%80%99aimerais%20ajouter%20quelques%20ex%C3%A9cutions%20suppl%C3%A9mentaires%20par%20la%20suite.%20Comment%20je%20fais%20%C3%A7a%3F%20(Par%20exemple%2C%20si%20je%20prends%20le%20m%20%3D%207%20et%20supprime%20les%20deux%20derni%C3%A8res%20colonnes%20et%20le%20compare%20au%20m%20%3D%205%2C%20je%20n'aurai%20plus%20les%20m%C3%AAmes%20lignes).%20Merci!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32977%22%20slang%3D%22en-US%22%3EBradley%20Jones%20a%20%C3%A9crit%3A%20Il%20est%20toujours%20bon%20de%20planifier%20pour%20valida%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32977%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Bradley%20Jones%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EIl%20est%20toujours%20bon%20de%20planifier%20des%20validations.%20Ce%20sont%20des%20ex%C3%A9cutions%20que%20vous%20faites%20apr%C3%A8s%20avoir%20ex%C3%A9cut%C3%A9%20le%20test%20et%20analys%C3%A9%20les%20donn%C3%A9es.%20Le%20r%C3%A9sultat%20de%20l'analyse%20est%20un%20mod%C3%A8le%20que%20vous%20pouvez%20utiliser%20pour%20pr%C3%A9dire%20les%20r%C3%A9ponses%20avec%20des%20param%C3%A8tres%20de%20facteurs%20qui%20n'ont%20pas%20%C3%A9t%C3%A9%20ex%C3%A9cut%C3%A9s%20dans%20l'exp%C3%A9rience.%20En%20fonction%20de%20votre%20objectif%20pour%20une%20r%C3%A9ponse%2C%20vous%20pouvez%20choisir%20d'ex%C3%A9cuter%20vos%20analyses%20de%20v%C3%A9rification%20selon%20un%20param%C3%A8tre%20de%20facteur%20(ou%20des%20param%C3%A8tres)%20pour%20lequel%20votre%20mod%C3%A8le%20pr%C3%A9dit%20l'am%C3%A9lioration%20la%20plus%20importante.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECela%20diff%C3%A8re%20de%20l%E2%80%99augmentation%20de%20la%20conception%2C%20qui%20%C3%A9tend%20la%20gamme%20des%20facteurs%2C%20ajoute%20des%20termes%20au%20mod%C3%A8le%20ou%20ajoute%20des%20analyses%20suppl%C3%A9mentaires%20pour%20r%C3%A9duire%20l%E2%80%99incertitude%20li%C3%A9e%20aux%20estimations%20dans%20le%20mod%C3%A8le%20actuel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32976%22%20slang%3D%22en-US%22%3EBradley%20Jones%20a%20%C3%A9crit%3A%20Je%20crois%20en%20l'utilisation%20courante%20du%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32976%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Bradley%20Jones%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EJe%20crois%20en%20l'utilisation%20courante%20du%20concepteur%20personnalis%C3%A9%20pour%20la%20plupart%20des%20probl%C3%A8mes%20de%20conception%20industrielle%20d'exp%C3%A9riences.%20Lorsque%20presque%20tous%20les%20facteurs%20sont%20continus%20et%20peuvent%20%C3%AAtre%20modifi%C3%A9s%20de%20mani%C3%A8re%20ind%C3%A9pendante%20sur%20toute%20leur%20gamme%2C%20les%20conceptions%20de%20d%C3%A9pistage%20d%C3%A9finitif%20sont%20un%20bon%20choix.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJ'utilise%20parfois%20des%20plans%20factoriels%20complets%20lorsque%20je%20fais%20des%20%C3%A9tudes%20de%20simulation%20sur%20ordinateur%20%C3%A0%20la%20m%C3%A9thode%20de%20Monte%20Carlo%20o%C3%B9%20la%20seule%20d%C3%A9pense%20est%20le%20temps%20pass%C3%A9%20sur%20l'ordinateur.%20Je%20conviens%20qu'il%20existe%20maintenant%20de%20meilleurs%20choix%20que%20les%20plans%20factoriels%20fractionnaires%20%C3%A0%20deux%20niveaux.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32975%22%20slang%3D%22en-US%22%3ESteven%20Moore%20a%20%C3%A9crit%3A%20Alors%20...%20j'utilise%20Definitive%20Sc%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32975%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Steven%20Moore%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EDonc%E2%80%A6%20J'utilise%20des%20conceptions%20de%20d%C3%A9pistage%20d%C3%A9finitives%20ainsi%20que%20des%20conceptions%20personnalis%C3%A9es%20depuis%20un%20certain%20temps.%20%C3%80%20mon%20avis%2C%20il%20n%E2%80%99ya%20plus%20de%20raison%20d%E2%80%99utiliser%20les%20dessins%20factoriels%20traditionnels.%20Ai-je%20raison%20ou%20manque-t-il%20quelque%20chose%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32974%22%20slang%3D%22en-US%22%3EJo%20Chotix%20a%20%C3%A9crit%3A%20On%20dirait%20que%20nous%20pourrons%20varier%20les%20uns%20les%20autres%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32974%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Jo%20Chotix%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EOn%20dirait%20que%20nous%20pourrons%20faire%20varier%20chacun%20des%20composants%20ind%C3%A9pendamment.%20Devrais-je%20planifier%20des%20essais%20de%20validation%3F%20Comment%20planifier%20ces%20facteurs%20%2F%20facteurs%20dans%20la%20conception%20(nombre%20d'essais%2C%20quels%20points%20de%20conception%20pour%20la%20validation%2C%20etc.)%3F%20En%20quoi%20est-ce%20diff%C3%A9rent%20d%E2%80%99augmenter%20la%20conception%3F%20Merci!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32973%22%20slang%3D%22en-US%22%3EBradley%20Jones%20a%20%C3%A9crit%3A%20Il%20pourrait%20%C3%AAtre%20appropri%C3%A9%20d'utiliser%20un%20DSD%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32973%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Bradley%20Jones%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EIl%20peut%20%C3%AAtre%20appropri%C3%A9%20d%E2%80%99utiliser%20un%20DSD%20mais%20je%20crains%20que%20les%204%20facteurs%20qui%20modifient%20la%20concentration%20du%20traitement%20ne%20soient%20consid%C3%A9r%C3%A9s%20comme%20des%20ingr%C3%A9dients%20d%E2%80%99un%20m%C3%A9lange.%20Si%20tel%20est%20le%20cas%2C%20l'utilisation%20d'un%20DSD%20serait%20inappropri%C3%A9e%2C%20%C3%A0%20une%20exception%20pr%C3%A8s.%20Si%20l'ingr%C3%A9dient%20majoritaire%20dans%20le%20m%C3%A9lange%20est%20une%20charge%20inactive%2C%20les%20autres%20ingr%C3%A9dients%20peuvent%20%C3%AAtre%20modifi%C3%A9s%20ind%C3%A9pendamment.%20Dans%20ce%20cas%2C%20un%20DSD%20serait%20OK%20%C3%A0%20utiliser.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32972%22%20slang%3D%22en-US%22%3EJo%20chotix%20a%20%C3%A9crit%3A%20Je%20pensais%20utiliser%20DSD%20pour%20concevoir%20un%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32972%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Jo%20chotix%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EJe%20pensais%20utiliser%20DSD%20pour%20concevoir%20un%20plan%20de%20traitement%20pour%20une%20%C3%A9tude%20in%20vivo%20sur%20la%20souris.%20J'ai%204%20facteurs%20qui%20modifient%20la%20concentration%20du%20traitement%20(par%20exemple%2C%20m%C3%A9dicament%20concass%C3%A9%2C%20m%C3%A9langes%20d'excipients%2C%20etc.)%20et%20un%20facteur%20centr%C3%A9%20sur%20l'%C3%A2ge%20des%20souris.%20Je%20me%20demandais%20si%20c'%C3%A9tait%20quelque%20chose%20pour%20lequel%20vous%20recommanderiez%20DSD%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32971%22%20slang%3D%22en-US%22%3EBradley%20Jones%20a%20%C3%A9crit%3A%20Vous%20pouvez%20ajouter%203%20facteurs%20cat%C3%A9goriques%20%C3%A0%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32971%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Bradley%20Jones%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EVous%20pouvez%20ajouter%203%20facteurs%20cat%C3%A9goriels%20%C3%A0%20un%20DSD%20sans%20rendre%20la%20conception%20inefficace.%20Vous%20trouverez%20ci-dessous%20une%20r%C3%A9f%C3%A9rence%20%C3%A0%20un%20article%20que%20Chris%20Nachtsheim%20et%20moi%20avons%20publi%C3%A9%20%C3%A0%20ce%20sujet.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJones%2C%20Bradley%20et%20Nachtsheim%2C%20CJ%20(2013)%2C%20%C2%ABMod%C3%A8les%20de%20s%C3%A9lection%20d%C3%A9finitifs%20avec%20ajout%20de%20facteurs%20cat%C3%A9goriques%20%C3%A0%20deux%20niveaux%C2%BB%2C%20Journal%20of%20Quality%20Technology%2C%2045%3A%202%2C%20120-129.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32970%22%20slang%3D%22en-US%22%3EEwoud%20Schuring%20a%20%C3%A9crit%3A%20Bonjour%20Bradley%2C%20blog%20int%C3%A9ressant%2C%20un%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32970%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Ewoud%20Schuring%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EBonjour%20Bradley%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBlog%20int%C3%A9ressant%2C%20en%20fait%2C%20tout%20le%20DSD%20m%E2%80%99int%C3%A9resse%20beaucoup.%20Cependant%20j'ai%20une%20question.%3C%2FP%3E%3CP%3EQuelle%20est%20la%20limite%20du%20nombre%20de%20facteurs%20cat%C3%A9goriels%20dans%20un%20DSD%3F%20En%20ce%20moment%2C%20j'essaie%20de%20cr%C3%A9er%20un%20DSD%20avec%203%20facteurs%20continus%20et%203%20facteurs%20cat%C3%A9goriels.%20Est-ce%20une%20bonne%20id%C3%A9e%3F%20Quels%20sont%20les%20risques%3F%20Ou%20bien%20un%20rapport%201%2F1%20entre%20continu%20et%20cat%C3%A9gorique%20entra%C3%AEne-t-il%20une%20conception%20non%20efficace%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32969%22%20slang%3D%22en-US%22%3EBradley%20Jones%20a%20%C3%A9crit%3A%20Paul%2C%20La%20conception%20personnalis%C3%A9e%20avec%20quelques%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32969%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Bradley%20Jones%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EPaul%2C%3C%2FP%3E%3CP%3ELa%20conception%20personnalis%C3%A9e%20avec%20quelques%20r%C3%A9pliques%20est%20une%20conception%20de%20surface%20de%20r%C3%A9ponse%20tr%C3%A8s%20s%C3%BBre.%20D'apr%C3%A8s%20mon%20exp%C3%A9rience%2C%20il%20y%20a%20g%C3%A9n%C3%A9ralement%20peu%20d'effets%20importants%20de%20second%20ordre.%20Il%20est%20donc%20excessif%20de%20cr%C3%A9er%20une%20conception%20capable%20d%E2%80%99estimer%20chaque%20effet%20du%202%20e%20ordre.%20Le%20DSD%20%C3%A0%206%20facteurs%20ne%20n%C3%A9cessite%20que%2013%20ex%C3%A9cutions%20et%20peut%20identifier%20de%20mani%C3%A8re%20fiable%20deux%20ou%20trois%20effets%20de%20second%20ordre.%20Cela%20vous%20permettrait%20d'%C3%A9conomiser%20pr%C3%A8s%20de%2050%25%20des%20co%C3%BBts.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESi%20au%20lieu%20de%20cela%20vous%20utilisiez%20le%20DSD%20%C3%A0%208%20facteurs%20et%20ignoriez%20les%203%20derni%C3%A8res%20colonnes%2C%20vous%20auriez%20un%20plan%20de%2017%20ex%C3%A9cutions%20et%20vous%20devriez%20pouvoir%20identifier%20quatre%20ou%20cinq%20effets%20de%20second%20ordre.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32968%22%20slang%3D%22en-US%22%3EPaul%20Prew%20a%20%C3%A9crit%3A%20Bonjour%20Bradley%2C%20cet%20article%20me%20rend%20th%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32968%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Paul%20Prew%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EBonjour%20Bradley%2C%20cet%20article%20me%20fait%20penser%20%C3%A0%20des%20conceptions%20appropri%C3%A9es%20pour%204-6%20facteurs.%20En%20particulier%2C%20la%20semaine%20derni%C3%A8re%2C%20un%20chimiste%20a%20voulu%20%C3%A9tudier%20cinq%20facteurs%20continus.%20Des%20tests%20pr%C3%A9liminaires%2C%20un%20facteur%20%C3%A0%20la%20fois%2C%20lui%20ont%20r%C3%A9v%C3%A9l%C3%A9%20qu%E2%80%99ils%20%C3%A9taient%20importants.%20Elle%20ne%20savait%20rien%20du%20DOE%2C%20mais%20son%20superviseur%20lui%20avait%20dit%20que%20c'%C3%A9tait%20un%20chemin%20plus%20efficace%3A%20allez%20parler%20%C3%A0%20un%20statisticien.%3C%2FP%3E%3CP%3ENous%20nous%20trouvions%20dans%20une%20zone%20grise%20o%C3%B9%20une%20simple%20projection%20aurait%20sembl%C3%A9%20%C3%AAtre%20un%20pas%20en%20arri%C3%A8re%2C%20inefficace.%20Nous%20avons%20donc%20choisi%20de%20concevoir%20un%20mod%C3%A8le%20quadratique%20conduisant%20%C3%A0%20une%20conception%20personnalis%C3%A9e%20de%2025%20ex%C3%A9cutions%20avec%20quelques%20r%C3%A9pliques.%3C%2FP%3E%3CP%3EMerci%20Paul%3C%2FP%3E%3CP%3EUn%20DSD%20%C3%A0%205%20facteurs%20aurait%20%C3%A9t%C3%A9%20beaucoup%20moins%20volumineux%2C%20m%C3%AAme%20en%20pr%C3%A9voyant%206%20ou%207%20facteurs%20et%20en%20supprimant%20les%20colonnes%20suppl%C3%A9mentaires.%20Comment%20puis-je%20utiliser%20JMP%20pour%20%C3%A9valuer%20le%20DSD%20comme%20une%20bonne%20conception%20pour%20l%E2%80%99adaptation%20d%E2%80%99un%20mod%C3%A8le%20de%20second%20ordre%3F%20Quels%20outils%20d'%C3%A9valuation%20de%20conception%20recommanderiez-vous%20pour%20comparer%20le%20DSD%20avec%20la%20conception%20personnalis%C3%A9e%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32967%22%20slang%3D%22en-US%22%3ERon%20Andrews%20a%20%C3%A9crit%3A%20J'ai%20trouv%C3%A9%20une%20application%20pour%20un%20DSD%20avec%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32967%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Ron%20Andrews%20%3C%2FSTRONG%3E%20a%20%C3%A9crit%3A%3C%2FP%3E%3CP%3EJ'ai%20trouv%C3%A9%20une%20application%20pour%20un%20DSD%20avec%20un%20m%C3%A9lange%20qui%20a%20fonctionn%C3%A9.%20Je%20devais%20confirmer%20les%20sp%C3%A9cifications%20de%20pes%C3%A9e%20pour%20un%20m%C3%A9lange%20de%20monom%C3%A8res%20utilis%C3%A9s%20dans%20la%20fabrication%20de%20lentilles%20de%20contact.%20C'est%20un%20vrai%20m%C3%A9lange%2C%20pas%20une%20solution%2C%20donc%20un%20DSD%20ne%20serait%20pas%20un%20bon%20choix%20dans%20la%20plupart%20des%20cas.%20Ce%20qui%20l%E2%80%99a%20fait%20fonctionner%2C%20c%E2%80%99est%20la%20faible%20variation%20par%20rapport%20%C3%A0%20la%20valeur%20nominale.%20La%20formule%20nominale%20a%20%C3%A9t%C3%A9%20utilis%C3%A9e%20comme%20point%20central.%20Chaque%20composante%20variait%20de%20%2B%2F-%201%25%20de%20la%20valeur%20nominale.%20Pour%20analyser%20l'exp%C3%A9rience%2C%20j'ai%20calcul%C3%A9%20les%20concentrations%20r%C3%A9elles%20pour%20chaque%20m%C3%A9lange.%20Il%20existait%20une%20corr%C3%A9lation%20significative%20entre%20les%20deux%20composants%20les%20plus%20importants%20du%20m%C3%A9lange%2C%20mais%20la%20conception%20permettait%20des%20estimations%20s%C3%A9par%C3%A9es%20des%20deux%20facteurs.%3C%2FP%3E%3CP%3EJ'ai%20soumis%20un%20r%C3%A9sum%C3%A9%20pour%20une%20pr%C3%A9sentation%20au%20sommet%20de%20la%20d%C3%A9couverte%20qui%20l'inclut%20comme%20l'un%20des%20exemples%20de%20solutions%20de%20rechange%20pour%20la%20conception%20de%20m%C3%A9langes.%20Que%20cela%20soit%20accept%C3%A9%20ou%20non%2C%20je%20peux%20fournir%20plus%20de%20d%C3%A9tails.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-275867%22%20slang%3D%22en-US%22%3EObjet%3A%20Utilisation%20appropri%C3%A9e%20et%20incorrecte%20des%20conceptions%20de%20d%C3%A9pistage%20d%C3%A9finitif%20(DSD)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-275867%22%20slang%3D%22en-US%22%3E%3CP%3EBrad%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMerci%20pour%20ces%20informations%20suppl%C3%A9mentaires%20sur%20la%20bonne%20utilisation%20de%20DSD.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIl%20y%20a%20environ%20un%20an%2C%20j'ai%20utilis%C3%A9%20DSD%20pour%20une%20simulation%20par%20ordinateur%20avec%20environ%20100%20facteurs%20continus%20qui%20n%C3%A9cessitaient%20%C3%A9galement%20tous%20les%20effets%20de%20second%20ordre%2C%20avec%20un%20nombre%20total%20d'ex%C3%A9cutions%20d'environ%20200.%20Les%20r%C3%A9sultats%20n'%C3%A9taient%20pas%20aussi%20satisfaisants%20que%20ceux%20d'un%20design%20personnalis%C3%A9.%20Depuis%20lors%2C%20j'ai%20h%C3%A9sit%C3%A9%20%C3%A0%20utiliser%20DSD%20pour%20la%20mod%C3%A9lisation%20et%20la%20simulation%20o%C3%B9%20il%20y%20a%20beaucoup%20de%20facteurs%2C%20bien%20que%20je%20trouve%20que%20le%20DSD%20soit%20un%20nombre%20de%20facteurs%20tr%C3%A8s%20utile%2C%20disons%20inf%C3%A9rieur%20%C3%A0%2012.%20Dois-je%20avoir%20utilis%C3%A9%20uniquement%20les%20effets%20principaux%20dans%20les%20ex%C3%A9cutions%20M%26amp%3BS%2C%20puis%20ex%C3%A9cuter%20un%20autre%20DSD%20avec%20un%20nombre%20de%20facteurs%20beaucoup%20plus%20petit%20pour%20confirmer%20les%20effets%20de%20second%20ordre%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EManny%3C%2FP%3E%3C%2FLINGO-BODY%3E
Proper and improper use of Definitive Screening Designs (DSDs)
In 2011, my colleague Prof. Chris Nachtsheim and I introduced Definitive Screening Designs (DSDs) with a paper in the Journal of Quality Technology. A year later, I wrote a JMP Blog post describing these designs using correlation cell plots. Since their introduction, DSDs have found applications in areas as diverse as paint manufacturing, biotechnology, green energy and laser etching.
When a new and exciting methodology comes along, there is a natural inclination for leading-edge investigators to try it out. When these investigators report positive results, it encourages others to give the new method a try as well.
I am a big fan of DSDs, of course, but as a co-inventor I feel a responsibility to the community of practitioners of design of experiments (DOE) to be clear about their intended use and possible misuse.
So when should I use a DSD?
As the name suggests, DSDs are screening designs. Their most appropriate use is in the earliest stages of experimentation when there are a large number of potentially important factors that may affect a response of interest and when the goal is to identify what is generally a much smaller number of highly influential factors.
Since they are screening experiments, I would use a DSD only when I have four or more factors. Moreover, if I had only four factors and wanted to use a DSD, I would create a DSD for six factors and drop the last two columns. The resulting design can fit the full quadratic model in any three of the four factors.
DSDs work best when most of the factors are continuous. That is because each continuous factor has three levels, allowing an investigator to fit a curve rather than a straight line for each continuous factor.
When is using a DSD inappropriate?
Below, the optimal split-plot design dramatically outperforms the Definitive Screening Design created by sorting the hard-to-change factor, wp. See point 4) below.
 Graph shows the comparative power of an optimal split-plot design vs. a Definitive Screening Design created by sorting the hard-to-change factor.
1) When there are constraints on the design region
An implicit assumption behind the use of DSDs is that it is possible to set the levels of any factor independently of the level of any other factor. This assumption is violated if a constraint on the design region makes certain factor combinations infeasible. For example, if I am cooking popcorn, I do not want to set the power at its highest setting while using a long cooking time. I know that if I do that, I will end up with a charred mess.
It might be tempting to draw the ranges of the factors inward to avoid such problems, but this practice reduces the DSD’s power to detect active effects. It is better to use the entire feasible region even if the shape of that region is not cubic or spherical.
2) When some of the factors are ingredients in a mixture
Similarly, using a DSD is inappropriate if two or more factors are ingredients in a mixture. If I raise the percentage of one ingredient, I must lower the percentage of some other ingredient, so these factors cannot vary independently by their very nature.
3) When there are categorical factors with more than two levels
DSDs can handle a few categorical factors at two levels, but if most of the factors are categorical, using a DSD is inefficient. Also, DSDs are generally an undesirable choice if categorical factors have more than two levels. A recent discussion in The Design of Experiment (DOE) LinkedIn group involved trying to modify a DSD to accommodate a three-level categorical factor. Though this is possible, it required using the Custom Design tool in JMP treating the factors of the DSD as covariate factors and adding the three-level categorical factor as the only factor having its levels chosen by the Custom Design algorithm.
4) When the DSD is run as a split-plot design
It is also improper to alter a DSD by sorting the settings of one factor so that the resulting design is a split-plot design. For the six factor DSD, the sorted factor would have only three settings. There would be five runs at the low setting, three runs at the middle setting and give runs at the high setting. Using such a design would mean that inference about the effect of the sorted factor would be statistically invalid.
5) When the a priori model of interest has higher order effects
For DSDs, cubic terms are confounded with main effects, so identifying a cubic effect is impossible.
Regular two-level fractional factorial designs and Plackett-Burman designs are also inappropriate for most of the above cases. So, they are not a viable alternative.
What is the alternative to using a DSD in the above cases?
For users of JMP, the answer is simple: Use the Custom Design tool.
The Custom Design tool in JMP can generate a design that is built to accommodate any combination of the scenarios listed above. The guiding principle behind the Custom Design tool is
“Designs should fit the problem rather than changing the problem to suit the design.”
Final Thoughts
DSDs are extremely useful designs in the scenarios for which they were created. As screening designs they have many desirable characteristics:
1) Main effects are orthogonal.
2) Main effects are orthogonal to two-factor interactions (2FIs) and quadratic effects.
3) All the quadratic effects of continuous factors are estimable.
4) No 2FI is confounded with any other 2FI or quadratic effect although they may be correlated.
5) For DSDs with 13 or more runs, it is possible to fit the full quadratic model in any three-factor subset.
6) DSDs can accommodate a few categorical factors having two levels.
7) Blocking DSDs is very flexible. If there are m factors, you can have any number of blocks between 2 and m.
8) DSDs are inexpensive to field requiring only a minimum of 2m+1 runs.
9) You can add runs to a DSD by creating a DSD with more factors than necessary and dropping the extra factors. The resulting design has all of the first seven properties above and has more power as well as the ability to identify more second-order effects.
In my opinion, the above characteristics make DSDs the best choice for any screening experiment where most of the factors are continuous.
However, I want to make it clear that using a DSD is not a panacea. In other words, a DSD is not the solution to every experimental design problem.
Article Labels
24 Comments
