New contingency analysis add-in for JMP
A contingency analysis determines whether there is a relationship between two categorical variables. A caterer, for example, might be interested in knowing whether entrée selections at an event were related to gender, given the following data:
image_1
The contingency platform in JMP requires the X and Y variables to be contained in two columns, with the cell counts in a third:
image_2
With the “Contingency (Table Format)” add-in, developed especially for students and others who are new to JMP, you can launch a contingency analysis with data that is arranged in “crosstab” format, without having to stack the data first:
image_3
Simply specify the variables as shown here:
image_4
The add-in creates the contingency report and includes buttons that let you easily swap the rows and columns of the report if desired:
image_5
If the “Show New Table” option is selected, the add-in also generates a stacked table containing a script that will launch the platform in the standard manner:
image_6
This add-in, along with many others, is available on the JMP File Exchange. (A free SAS profile is needed for access.)
Article Labels
